Question about Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer feq1442es dryer error code E95? power but will not start
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: frigidaire dryer feq1442e error code
The error code 9E indicates that low voltage is being detected at the control board of the dryer. This could be caused by the following factors:
  • The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
  • Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
  • If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board. (NOTE: The dryer should always be unplugged when accessing internal components.) A loose wire or burned connection in this area could result in this error code.
  • A failed control board could cause this problem.
If you are unable to determine and repair the cause of this problem, I recommend calling a service technician to diagnose and repair your dryer.
Good Luck
Please rate FixYa!
Posted on Dec 19, 2008
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire FEQ1442ES Electric Dryer not producing
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Posted on Oct 10, 2010
Dryer will not start
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not start. I also see that when you press the start button, the lights above the Control button blink and your dryer beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dryer will not start: when I hit the start button, dryer beeps and lights blink above Control button
-Best Regards-
WP
Dryer works for 20 sec and then beeps 6 times and stops
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134420600es.pdf
this is a web site with you manuals. check it out and see if this does not get you started.
http://www.frigidaire.com/manuals
here is another with more manuals.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efs.pdf
this one reads the error codes.
Good luck.
May 01, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer overheats, already checked venting
Does the unit shut off when it overheats? According to the wiring diagram it could be the Heater Relay or High Limit Thermostat. See the wiring diagram for instructions on error codes and how to obtain them. It is easily found on their website. Hope this helps
Nov 25, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer feq1442e error code 9e, what does it mean?
Good Luck
Please rate FixYa!
Dec 19, 2008 | Frigidaire Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
223 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
