Question about Bosch 24 in. SHU43 Built-in Dishwasher
No Power to the front display. Just went out in the middle of a cycle. Have 120V going to the dishwasher. Could not find a reset button on the motor. All connections dry & look good. (no discoloration) My thought was the control pannel??
  • jtelladira_h Sep 29, 2010
    I have what I beleive to be the control module in my hand. The part in question hase a direct power line going to it from the main power switch. It is also the part that the buttons on the front connect to, as well as it has the digital timer.
    The part in question has a bad PCV Board.
    Now comes the problem of finding a replacement.
    Thanks for your assistance!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue seems to be with the electronic control going bad and should be replaced however, before replacing it take it apart and blow some air with the help of hair dryer so that if there is any moisture it blows it off. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 29, 2010
  • Rylee Smith
    Rylee Smith Sep 29, 2010
    You can buy the parts from this link. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • NoMorTosh4Me
    NoMorTosh4Me Oct 18, 2010
    First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model underhttp://microsites.boschappliances.com/sa...
    then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
Kuds30ivbl4
Check number six in diagram for continuity it is a thermal fuse and may of blown out.
Mar 15, 2015 | Dishwashers
I can not select a cycle on my belling idw450. Power is on
the program button on panel could be stuck or moisture in it. If there is no error displayed on panel, then take a hair dryer and on warm setting run it along the switch panel.
if error message is displayed then try to address the error first.
The program switch sits on top of the panel module which looks like this http://www.4ourhouse.co.uk/cgi-bin/product.pl?PID=1933696&query=Belling%20IDW450%20panel&model=IDW450&path=67231,297877:297772
It is the small board in front middle of the assembly.
Apr 20, 2014 | Dishwashers
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 10, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
THe dishwasher will not start.
what cycles does your dishwasher offer? there is a cancel reset. its usually holding scrub and econo wash at the same time while the power is on will activate the cancel drain mode then reset the dishwasher next time you power it. if that doesnt help then let me know your full model number and i will tell you exactly which buttons to press.
your model should read:
SHU66C05UC/??
what numbers are ??
Mar 03, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Has power all the way past the latch, but cycle selection buttons dont respond
Hi nipdoes2,
I'm Harvey the Master Plumber.
Your problem is: You followed the power as far as the door switch.
If you follow it past the door switch you'll find a bad control board. The power goes in but it doesn't come out. It's an integrated circuit so it must be replaced. Check with the manufacturer for the part.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Whirlpool SUD6000HQ Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
147 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
