When I print out a Word document the word ?DRAFT? appears across the page horizontally. Why?
  • 68 Answers
Go into the "properties/preference" of the printer, and under "extras" or something similar, look for "watermark". Be sure to set it to "No Watermark", else you'll get that "draft" stamp each time you print something.
Posted on Sep 29, 2010
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Despite inserting new black cartridge (Brother LC57 BK), print is faint and on spreadsheets is blurred and has horizontal lines across pictures.
Hi
If a single inkjet in your printer is not functioning then output will appear as a horizontal line across the page. If one of the jets is on all of the time then output will have black or colored lines across the page. Use the following steps to isolate the problem: - Replace the ink cartridge - Check the flexible cabling for continuity and for short circuits between adjacent conductors - Exchange the control board for a good one - Finally check the power supply
Good Luck
Mar 09, 2011 | Brother MFC 210C All-In-One InkJet Printer
It really prints so slow
Try setting the printing properties to fast draft or draft. It provides a average quality document faster using less ink.
To do this, go to Start->Control Panel and then Printers. Right click on your printer and choose printing preferences. Find the setting for the quality and select Draft or Fast Draft if it is available.
Please note that this printer has a rate of 5.36 pages per minute, so even with the draft you will not see much difference.
Regards,
nicolasiac
Feb 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
Feb 05, 2010 | Canon PIXMA MP610 InkJet Printer
Draft word
Hi. I'm not sure, but it sounds like you have a watermark set on the document. If you are using Microsoft WORD, go to PAGE LAYOUT and click WATERMARK, then REMOVE WATERMARK.  (I have Word 2007) I'm not sure how to do this on previous versions. Hope this helps.
Sep 15, 2008 | Xerox Phaser 8560MFP Laser Printer
Unwanted Horizontal lines across the printed page
Problem is either Laser, Toner cartridge or transfer roller.
Feb 15, 2008 | HP LaserJet 4000 Printer
Character spacing when printing 2 pages on A4
Hope this gives you an idea. When printing from your pc, please select print properties to draft/best printing resolution. We'll see the difference between fast draft to best. Else you'll have to allign the printer settings from your pc, using the printers alignment tool.
Best regards,
Rosener
Feb 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Jan 17, 2008 | HP LaserJet 2840 Printer
51 people viewed this question
jasbo
jasbo
