Question about Husqvarna Designer I
Need help!!!!! i need to calibrate the touch screen and the service mode buttons aren't working. i hold start stop , and pivot and i just get the normal startup screen
  • 201 Answers
This is the advice Stevanos gave to someone else with the same problem:
"switch on while holding in reverse
Posted on Oct 05, 2010
  • buysellgb Jan 23, 2011
    DnC Sourcing is to make an Expert of developing products. ---> www.artdnc.com (82) 70-7893-2100)http://www.sourcingbuysell.com
    We have 15 years developing experiences and will implement the advanced products to our customer.
    Electronics, home appliances, sporting goods, medical products, smart phone, General Phones, machine equipment, cattle. Midsize engine
    * Mechanical design, tooling, product design, machine design, reverse engineering (image), product design, MOLD Analysis
    * Processor: AVR series, DSP, FPGA, ARM7, ARM9, etc.
    * Circuit design, PCB ARTWORK Use Program: ORCAD, PADS
    70% Motor Sales ---> www.buysellmotor.net, sourcing everything ->http://www.sourcingbuysell.com
Pc-8500 how to calibrate touch screen
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
My Kenmore 19001 touch screen works when I am sewing regular stuff, but when I put in the embroidery card - I can see the designs on the touch screen but nothing happens when I try to go to a design. I...
to recalibrate the machine press the stop/start; the reverse; and the knot button at the same time and while holding it down turn the machine on.
Sep 28, 2012 | Kenmore 19001
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
Hi Can u please tell me how to calibrate my Designer 1? Have not done it for a few years and now I've forgotten. Also my touch screen is only partially responding....I'm not getting any response...
Hi Vina, Since you can't get any response to your Menu-Norm-Prog-Rep-Set-or Help on your touch screen but you can get into your stitches, It does sound like you need to re-calibrate your touch screen. Normally you would get into your Set Menu to access your touch screen calibration. But as suggested on another solution. You turn off your Des 1, Holding in the reverse button (bottom left of the eight buttons) and the pivot button (the second one from the bottom of the four buttons) at the same time and turn on your machine. This is the Service menu that pops up (try not to touch anything on this screen, it could really mess things up if you don't know what you are doing) After this screen pops up go over to the eight buttons on the far left of your machine and touch the needle up, needle down button (top right button of the eight) the Calibration Screen will pop up on your touch screen (two plus marks labeled 1 & 2) In your sewing sitting position touch the center of the #1 mark and then the #2 mark. Once you've done that the Service Screen will pop back up. Shut off your Des 1 and restart it normally. Try getting into your different menus- Menu-Norm-Prog Etc. Hopefully that fixed your Calibration issue! ** Note: If the service menu doesn't pop up when trying to hold in these 2 buttons together and turning on your Des 1 the buttons weren't held in properly and you need to turn it off and try it again. Hopefully that helped you out!! Happy Sewing!! Kathy
Nov 24, 2010 | Husqvarna Designer I
HOW TO CALIBRATE MY DESIGNER 1 SCREEN the screen is off if i touch program nothing happens and the arrows are off to the right side
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again,and it should be fixed. Regards, Cathy.
Sep 15, 2010 | Husqvarna Designer I
Janome MC 9000 off touch screen calibration
Thanks guys
I remembered the fix!!
On the Janome MC 9000
To calibrate the touch screen
1. Turn off
2. on Sewing arm above needle there are a series of buttons
3. Hold down bottom 3 buttons
4. While holding turn on machine
5. Using scribe
6. Touch the centre of each + as it appears
7. It will go Centre bottom rh centre top lh as you select each + position it moves of it's own accord.
8. Turn off machine
9 Turn on and test.
Important sometimes this does not entirely fix prob!!
Simply do it again "Yahoo""
Some mechanics will try to tell U the screen is on it's way out
Bollocks just calibrate.
Thanks
CYA
Nov 16, 2009 | Janome Memory Craft 9000 Computerized...
How do you recalibrate the touch screen on the Quantum XL-1000?
Enter service mode....
Press the start/stop switch and hold it while you power the machine on.
THEN, press the reverse switch, hold it and press the lcd. Release the reverse switch AFTER you touch the LCD.
Nov 15, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Viking Designer 2 service mode
Hold down the start/stop button and the presser foot pivot button at the same time and turn the power on. You may need to try it a few times.
Hope that helps.
Feb 11, 2009 | Husqvarna Viking 1
Problems recalibrating Designer 1
switch on while holding in reverse & pivot buttons. release then press needle stop button. calibration marks will appear. set & restart.
Jun 27, 2008 | Husqvarna Designer I
My touch screen doesn't always work. Sometimes I have to touch all around the square and even then, it won't come on. At times, it stops working when I want to change patterns. It seems to work most of the...
Yes, I have a solution for this problem. Your screen needs to be recalibrated and you can do it yourself. Don't you wish they would just tell you this stuff instead of charging you an arm and a leg? Here's what to do: Before turning on the machine, press the start/stop button, the reverse button, and the needle position button all at once with one hand (one finger on each button). Hold them down and turn on the machine. What will come up is a recalibration screen. You will see the numbers 1-5 with a little plus sign beside them. Find a small blunt object (I used the tip of a mechanical pencil with the lead in instead of out) and while holding the start/stop button, touch the plus sign beside 1-5 in numerical order. Then, turn the machine off and on again in the normal way. This should recalibrate the screen. Pass it along, people! This is something no one should have to pay for!
Nov 03, 2007 | Baby Lock Esante
Sewing Machines Logo
108 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
