Question about Memorex Office Equipment & Supplies
I have a Memorex Shredder, Model MPS-2800. The red light on the bin full indicator stays on constantly. The shredder will not turn on or off or reverse. Do you have any suggestions? There is possibly a part broken on the underside, but, I'm not sure about that. The part that it looks like it could be is a "flap" that it looks as if one of the "legs" may be broken that goes down and activates the switches.
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
SOURCE: DM15C stops after 4 seconds, open bin light comes on
This solution worked great! Thank you
Posted on Apr 15, 2008
SOURCE: Office max shredder om96431
For me, the problem was the sensor connections. I took the unit apart (7 phillips screws, I'm not sure why I didn't have to remove the 8th.) Then I took the paper sensor unit off (2 more phillips screws.) Then I removed the little black box that both sensor wires are connected to (1 more phillips screw.) Then I pried that box open with a flat head screwdrive. Some parts fell out. I put it all back together and it worked.
If you don't want to mess with it, just remove the two wires and tie them together. The unit will always be on when turned on to Auto, but that's better than not working.
Posted on Aug 27, 2008
  • 35 Answers
SOURCE: intimus 600 shredder
The plastic reverse pushbutton over the soft touch keypad is broken/stuck in or down causing this problem. A new pushbutton cover is needed. How are the Forward and Stop buttons?
Posted on Feb 23, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
Our shredder will not anymore shred the red light will signal
Blades probably Jammed
Safety First
Power Disconnected
Open up and free the mechanism
Apr 05, 2016 | Shredder Office Equipment & Supplies
Do you need to lube a mps-2800
Hello. Yes you do with electrical grease only.
Apr 18, 2014 | Memorex MPS-2800 5 Sheet Cross Cutt Paper...
Do you ever need to lube a memorex paper shredder
ALL shredders need to be lubricated. When metal turns, it creates friction that, over time, can cause the blades to warp. Just like you have to add oil to a car, shredders must be oiled as well. You can buy bottles of oil at your local office supply store. Just squirt across the top of the blades. Or pour some on a plate, dip a piece of paper in it, then shred. If you want less mess, purchase the pre-lubricated sheets that you can just drop in and shred. Make sure to shred in reverse about half way through to get the best results.
Shredder wont shred
My boss has a shredder that will not run unless the bin is exactly centered in the bottom of the unit. There is a safety switch inside there, and a magnet to activate it. Make sure nothing is interfering with the bin or the shredder fitting together.
On other units, there is a slot that must match up with the shredder. It will only work one way. See of the shredder will turn around and put it on the bin the other way.
Mar 10, 2012 | Aurora Electronics AS1018CD Shredder
Office max shredder, says bin full but its not, only half full
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Feb 08, 2010 | OfficeMax 0M96431 Shredder
Nov 11, 2009 | Fellowes DM15C Shredder
The basket full light will not go out
YOU WILL HAVE TO HAVE SENSORS REPLACED
Sep 15, 2009 | Fellowes DM15C Shredder
Open top
Remove the bag holder...look up inside and see 4 screws to remove.
Jun 28, 2009 | Memorex MPS1500 Strip Cut Shredder, With...
Staples SPL-1506X Shredder Issue
I had the same problem. I have a solution but I do not recommend this unless you have technical experience with repairing electrical appliances. I took the back cover of the main shredder unit to expose the wiring (there are 7 screws in total). The bin full sensor has a blue, green, and red connected to it. I clipped the blue wire to defeat the Bin Full error. You can look through the plastic window to check that the bin is full.
Apr 25, 2008 | Office Depot Ativa DQ60M Shredder
133 people viewed this question
Top Memorex Office Equipment & Supplies Experts
ray gallant
Are you a Memorex Office Equipment and Supply Expert? Answer questions, earn points and help others
