Question about Arris WR850G Router (DHWR850G)
Modem light is blank on motorola wr850g, how do i fix?
    Novelist:
  • 108 Answers
If the modem light is not turning ON,
1) check if the modem is ON
2) check if the ethernet connection is properly made
3) check if the port on the modem is working, confirm it by connecting it straight to the computer.
4) check if the ethernet cable is working fine.
5) Then try power cycling the router. Unplug the power cable and connect in back after 20-30 secs.
6) Then try pressing and holding the reset for 20 secs.
7) Finally connect a single ethernet cable from any LAN port to WAN port and check if the modem light is ON.
Ultimately, if even after this step, if the light doesn't turn up, either the modem LED would have gone bad or the WAN part of the router would have gone bad.
For further clarifications, revert!
Thanks for asking,
Regards,
Arvind S Iyer
Posted on Sep 29, 2010
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
May 15, 2013 | Arris WR850G Router (DHWR850G)
Secure motorola router WR850G
If you want set wireless router with connect your internet, in that case you should secure your wireless router.The router transmits and receives data from the modem and computers connected to the network....read more: how to secure your router
Aug 28, 2012 | Arris WR850G Router (DHWR850G)
My router is plugged into my modem but the modem Light on the router is blinking red
Try unplugging the power cords on both for one minute and plug back in. Let me know if that fixes it or not.
Jul 03, 2011 | Arris Wireless G Broadband Router (wr850g)
Cannot connect to motorola wr850g router
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Jan 03, 2010 | Arris WR850G Router (DHWR850G)
Our internet went down for several hours (it was an area-wide problem with our server). Once the internet came back up, my motorola 850G router will not work. I have reset the router, but the modem light...
(It worked for me for WR850G, when I had a similar issue. However, don't know how your connection is setup.)
1. Switch-off the ISP modem that connects to the router
2. Switch off the wireless router
3. Now switch on the ISP modem
4. Switch on the wireless router
Regards,
Warija
Dec 22, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant get motorola wr850g to see time warner cable modem
I had same problem and what i did is i restarted the device and i installed it to the cp again you probably did something wrong
Aug 14, 2008 | Arris Wireless G Broadband Router (wr850g)
Cant connect to the internet
red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
Feb 05, 2008 | Arris WR850G Router (DHWR850G)
Motorola router
first check your computers internet connection settings.and also check for any updates that could pretain to your modem/or computer.the problem is with your main computer,and not with the router.second check your firewall,make sure the correct port is open to let the traffic in.
Dec 28, 2007 | Arris Wireless G Broadband Router (wr850g)
Slow speeds is caused by interfearace from cordless phones. 2.4ghz. also could need a power cycle. unplug the power from the back of your dsl modem. unplug the power from your router. shut down your computer. Plug in the modem frist, wait until all lights are green. plug in the router. then when lights are normal on that. turn on your computer. try your connection again. is it slow when you try to acess the router ip address?
Dec 06, 2007 | Arris WR850G Router (DHWR850G)
Arris WR850G Router (DHWR850G) Logo
209 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
