Question about Frigidaire GLTF2940ES Front Load Washer
Frigidare Gallery dishwasher GLDB958JS0
All buttons work except the start button. will not start on delay timer also.
  • C-130FE Sep 16, 2008
    On my dishwasher all the functions on the keypad won't work. The "NORMAL" wash cycle doesn't work. All the rest work just fine. The unit is about 4 years old. We've had some power outages and I don't know if it's related to the damage to the dishwasher.
  • 868 Answers
Your touch pad has to be replaced to fix this one, be cautious with any liquids getting into contact with ANY touch pad.When cleaning just use a damp cloth.
Posted on May 25, 2008
Start button won't work, but delay does
have you accidently turned on a safety feature stopping the machine from starting? or is the door latches closed fully, if opened slightly could be preventing the machine from starting. or maybe its just a faulty start button.
Jul 16, 2012 | Electrolux Frigidaire Professional Series...
ITS A NEW FRIGIDARE IT WILL NOT COLD TO FREEZE
Possibly stuck on defrost... locate the defrost timer and turn the timer dial... the fridge should come on.... but you still need to replace the timer
Jul 19, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Kodak easyshare C875. Can I take a delayed picture? If so, how?
In any still mode except for Panorama, press the self-timer button (on the top of the camera, marked with a one-handed clock) once for a ten-second delay, again for a two-second delay, and yet again for two pictures (after ten-seconds and eighteen-seconds). To start the self-timer, press the shutter release button.
Dec 15, 2010 | Kodak Cameras
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Shows a 7h when we try to start
this is the delay timer display unplug from wall leave for a couple of mins and try again,if still the same keep pressing time delay button till it reaches zero appliance should work if not the electronic pcb sound faulty.
Aug 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
ESL 63010 will not start program
does your dishwasher have a timer button on it? sounds like the switch behind the button needs to be replaced.
Sep 13, 2008 | Dishwashers
Cannot operate arrow buttons on clock or timer
Remove all of your buttons, and use the narrow end of a chopstick (or something else narrow but not sharp) to push the post of the button in, and it will work. I'm considering finding small ball bearings to put inside the buttons so they would be easier to push.
Jul 04, 2008 | Kitchen Ranges
Fault in the touch pad-replace the touch pad.If problem continues you have to replace the control board.
May 25, 2008 | Frigidaire Dishwashers
Frigidaire Dishwasher GLDB957JS0 (built-in)
Door switch had to be replaced. Turn off circuit breaker first.
Feb 27, 2007 | Frigidaire 24 in. GLDB957A - Multiple...
Frigidaire GLTF2940ES Front Load Washer Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
