Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not move to next step in cycle making a buzzing sound like something is jammed or its a short
  • 121 Answers
There is most likely something hung in the water pump. This page will show how to access the pump http://www.appliance-repair-it.com/Whirlpool-washer.html
Posted on Sep 29, 2010
My washer makes a buzzing sound when trying to go through spin cycle. Cold water doesn't work either but other temps do.
check for a faulty cold water solenoid in the machine
the buzzing noise is a cycle frequency noise caused when a solenoid coil is faulty and not moving the centre bit.
May 28, 2015 | Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Makes a weird buzzing sound while in the wash cycle, sounds like a problem with a relay perhaps
The timer sometimes will buzz like that, nothing to worry about usually, if the timer ever stops, and you can restart it by pulling out the knob and moving it a bit further in the cycle and restarting it, then your timer is going out.
But it may also be a bobby pin or something like it in the pump ,My atlantis has had this several times ( daughter never checks her pockets ) most times it travels on through in time, but a few times i needed to remove the front of the machine and pull the hoses off the pump and get the bugger out.
Nov 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
WASHER DOES NOT TURN
Sounds like the motor has frozen. Try to work the drum loose from the bottom (empty and unplugged) it just might be jammed from a pen or similar item lodged inside (someone not emptying their pockets). Since its buzzing (its the motor TRYING to move the drum) it has to be jammed from something. Rarely it could be a bearing locked up in either the drum or the motor itself though its unlikely.
Mar 21, 2009 | Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Kenmore dishwasher "sensing" light
the sensing light and buzzing are normal let it do that on its on then let me know what happens its a soil sensing light and is supposed to run a cycle on its own to clear it but lets see .we will go from there ok
Jan 17, 2008 | Kenmore Elite 45986 Front Load Washer
Will not start
bsolo, sounds like something jammed in your pump stopping the motor. You will have to remove the cabinet to get at the pump. It has 2 clips that hold it to the motor. The best way to tell for sure is to remove the cabinet, jump the lid switch and start the washer. If the motor runs without the pump, then you know for sure it's jammed. I will try to attach a diagram on how to remove the cabinet.6212c10.gif216ffff.jpg
Dec 06, 2007 | Roper RAX4232KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
