Question about ACE Allway Tools Allway Handy Saw Blades
Change a handy saw blade allway hb 24t - ACE Allway Tools Allway Handy Saw Blades
I need a new blade for my duracraft band saw model 20412 Where can I get one? my zip is 81006
bandsawparts.com. have brand and model# handy. GOOD LUCK FRIEND.
Nov 28, 2014 | Blade Saws
Saw blade stuck
Do you have the exact model of your saw handy?
Also, try some PB Blaster instead of WD40, it works much better at freeing up rusted or stuck parts. Let it sit a couple of hours and spray it a few times
Jul 28, 2012 | Hitachi Saws
I have just bought this model second hand, and the blade is fitted upside doen for some reason. How do i change blades?
Hi marill469,
Here is a website where you can download the owner's manual for your saw: http://www.retrevo.com/d/ds/progress?doc=e045b5a9143e1e2ea028b778addd77ca&rk=0.7594880065395843
The instructions for blade insertion and removal are on page 7.
As far as I know, there is no upside down on a recip saw blade. You can use it either way. Upside down allows you to get the blade in tighter spaces due to the shape of the saw.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 19, 2011 | Makita JR3050T Recipro Saw 9 Amp
Need to know how to change the agle on the blade for a protech 10 in table saw
Hi Ron,
You didn't give your model.
Protech is out of business so I could not find a user's guide for you.
The knob on the front that you use to raise and lower the blade also adjusts the angle. Depending on your saw, normally the knob releases from raise/lower mode to angle adjustment by either pulling the knob out and moving it or by pushing a lever to release it and then moving the knob.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Skil 10" Table Saw
My Ryobi P501 cordless saw is noisy, sounds like it may need bearings or gears.Are there any common problems with these units?
No but where did you buy it its a small saw mine works fine but its for limited use. You can't use it to cut frameing lumber but its handy.What have you done with it when was the last time you changed the blade ? Idon't know i have 5 or 6 differant skill saws differant blades differant uses its olny disigned to do so much
Dec 14, 2010 | Ryobi P501 18v Circular Saw Only
Can you repair a crack by welding the circular saw blade? And if so how? Thanks Mike
No because is made of one piece of material and if you weld it it going to bend duo to heat. So buy one!
Oct 13, 2010 | Blade 24- Irwin 7-1/4" X 24t Classic...
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
My skilsaw5150 still won't run.
OK I went to a Bosch website to find a breakdown and it could be a couple things. First unplug tool and do you have a volt ohms meter or continuity tester. If so start by checking cord from the plug to the switch and then depress switch and go to brush holders. You might have to remove brushes so it doesn't read across both of them How bad were the brushes you removed, were they burnt looking and if so try and look at the commutator to see any noticable discolored com bars. When you installed the new brushes it is also a possibility that they were sticking in the brush tubes and make sure that the holder pushes into the field connections properly. Let me know if you are still having trouble
Mar 31, 2009 | Blade 24- Irwin 7-1/4" X 24t Classic...
How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Mar 28, 2009 | Saws
ACE Allway Tools Allway Handy Saw Blades Logo
114 people viewed this question
Top ACE Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an ACE Measuring Tool and Sensor Expert? Answer questions, earn points and help others
