Question about Kenmore Dryers
Dryer will not get hot replaced element still have problem
  • Kenmore Master
  • 8,220 Answers
Do you have 240 volts going into the machine?dryer will not get hot - f0380b1.jpg
Do both of these safetys have continuity?10d168e.jpgWe know it is not the fuse since the dryer still runs. So if all of the above is fine then the timer might be bad. How do we check it? Find the fat red wire from the element going into the timer. Remove the wire and clamp a lead of your ohm meter there. Next try and see if you have continuity between that terminal and any other terminal on the timer. Slowly turn the timer knob while checking. If you cannot get a reading then your timer is bad.d113cad.jpg
Old school repair manual and photos here
More good stuff here
Posted on Sep 29, 2010
Continues to blow the high temp stat. I clean the blower and replaced the venting. I also replaced the heating coil the dryer heats up for a load and then it stopss heating. I test the high temp stat
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Feb 17, 2015 | Dryers
Dryer stay hot
It's very possible your element shorted to ground causing the element to get constant currant from the wall outlet if it was hot without running, if thats the case you need to replace the heating element.
Jan 15, 2014 | Dryers
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Kenmore dryer is not getting hot
More than likely the heating element has gone out. This element is located at the base of the dryer and is accessed through the back. It looks like a toaster oven element but a tad bit bigger. You can replace it yourself or have an appliance tech replace it for a minimum fee
Dave
Mar 21, 2010 | Dryers
Dryer not drying.Possible heating element not
One way to check if the element is working - is take the exost hose off the back & place a mirror behind the dryer so you can see if its glowing red hot or not..
Jul 08, 2009 | Dryers
Heating element to hot.
Replace the hi limit thermostat. it has failed.
Jun 25, 2009 | Frigidaire GLER341A Electric Dryer
Replaced element and now dryer too hot - vent is clear
Hi, Check the element again. It sounds like the element has relaxed and shorted out against the metal housing. The squeak might be the rear bearing cup. You can check and see if it needs grease while you have the drum out.
I hope this helps you. Please let me know.
Thanks
Vic
May 30, 2009 | Frigidaire GLER341A Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Dryers Logo
26 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
