Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Mixer will not come on. is there a reset buton?
  • KitchenAid Master
  • 17,129 Answers
Most of the sets come with a reset trip /load trip which can be seen on the side or underside of the unit.
so please check your power cord to leadd to the unit .If there is none it wil go to the power switch or the speed control unit.
Check the switch trace power to the motor, if power comes in , the motor must be checked.
Posted on Oct 01, 2010
How to reset the fuse if there is one?
Have an electrician test the socket that the mixer plugs in to and see if there is electricity there. You might also plug in something else to test it yourself. If the socket its good, your mixer is "broken".
If the socket is dead, you need to reset the breaker, or replace it.
God bless your efforts.
Jun 01, 2015 | Food Mixers
Mixer went into over load useing a stactic converter wont come back on no noisewhen turn on
This sounds the thermal reset is tripped have you looked for a red reset button on the mixer? that is usually what fixes that
Feb 28, 2011 | Hobart HL600 Legacy Stand Mixer
Mixer will not turn on. Is there a reset button?
There is no reset button. More than likely the speed control plate is bad. This is a common problem. I recommend storing the mixer unplugged and on the first speed. Also don't store it with the beater, whisk, or hook attached to the mixer. This may help save the control plate contacts from becoming sprung. Fixmymixer@aol.com
Feb 19, 2011 | KitchenAid K45SS Classic Stand Mixer
I have Butterfly brand mixer grinder from India. While operating it went off due to overload, but it's not working now. I tried pressing the reset button but still no use. Now, I opened the machine and...
I have the same problem with Butterfly Ivory Plus mixer in India.... The mixer went off with over load. I pressed the reset button, but still the mixer wont start. Looks like a common prob with butterfly mixers.
Nov 02, 2010 | Food Mixers
Mixer stopped working in middle of task, i guess it got too hot.
chances are you have oerloaded the mixer or it is unevenly loaded give it a few mins it may have a safty and a reset button check you main fuse box as well the toggle may need to be reset
Dec 23, 2009 | Oster 2384 Mixer
I have a 30+ yellow hamilton beach stand mixer. I would like to replace the beaters but unfortunately the model number has washed off. The beater are not hooked together and on of them has a little white...
Either you don't have a Hamilton Beach or, your beaters originally had a center bracket. They only made 2 styles of beaters for their stand mixers, short shaft & long shaft. They both had a buton on the one beater to turn the bowl. The portable mixers aren't joined but, they don't have the button either. I did their factory service for a few years (back in the 70's & 80's) and I never saw single beaters with a button.
Oct 20, 2009 | Hamilton Beach Food Mixers
Mixer revs, then shuts off, will not reset
your kitchen aid has a little device inside called the hall effect sensor. These often come dislodged or just stop functioning. If you are mechanically inclined you can replace this yourself.
Oct 01, 2009 | KitchenAid KV25G0X Stand Mixer
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Jun 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
534 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
