Question about HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive
Hp laptop charger is hot!!!!
Im a 16 year old boy and my laptop charger is very hot. one day i was in my room and i saw that my laptop was no longer charging so i went to touch the charger and it was so hot i was almost burned so i let it cool down in a cool place my living room and it start working again but now its always hot and its making a buzzing noise is this safe for my laptop its only the middle part thats hot. not the tip of it are anything.
  • 2 more comments
  • recon20011 Jun 12, 2008
    my laptop charger got hot one day and so i unplugged it and let it cool. Now it won't charge reliably, probably one time out of every 5 I plug it in will it charge the laptop. It emits a sound somewhere between a beep and a squeak when it isn't charging. I have noticed that when it does charge there is some sort of shock/static that comes out. It's never hurt me and it could be my imagination because I have only seen it and not felt it even when holding it. Thanks.
  • Anonymous Mar 10, 2009
    The other user, recon, has the same exact problem, Im 12 and I know that it overheated, now I just need to know what exactly burned up so bad in there and how to fix, otherwise, this stuff is a piece of **** and im buying a new one.
    I HAVE A TOSHIBA
  • Anonymous May 03, 2009
    same with mine i have went thru 2 chargers now and my hP oes not recognize that it is even charging any more??
  • raptorjmmy May 10, 2009
    well same thing happend to me i was had the wire plugged in and then the charge light on my laptop went out and the brick kept make beeping sounds so disconnected the charger after try many time to push the plug back in but it never worked should really replace my brick part of my charger and also the thing was burning hot.
    how long those the brick piece of the charger last anyways
    mine last close to 3 yr and finally broke down today.
    Problem Solver:
  • 5 Answers
It just happened to me it got over hearted and the fan in it is brunt wich make the noice u have to get a new one
Posted on Feb 22, 2010
  • fefe
    fefe Aug 11, 2014
    just purchased a pavilian and it does the same thing and it is not fare at all
Get a new one, or if you have some technical know how you can unscrew the middle part and see what really wrong. Something has probably melted. I have two batteries and both of them I took to Britain and since then I noticed the hotness cause I just replaced the front wire with a british one. So ya Repleace it, try toget it fixed or fix it yourself. I can be dangerous.
Posted on Mar 20, 2009
Same with me what i did was, i plugged it in while shut down until 100 percent..this wont fix the problem but reduce it, put the color qaulity down will help a little bit, lower your graphics options, and other stuff. if your online gaming or using something that has high graphics it might be the case.
Posted on Dec 16, 2009
Many of HP's laptop power supplies get very hot when in use. I've never had a problem with mine, per se, but my girlfriend and her brother both have the same laptop, and theirs get as hot as mine. Her brother's stopped working one day, and I took it to my shop. It provided 18.5 (actually 18.87) volts perfectly fine under no load, but when plugged into the laptop, it would get hot and after about 5m, stop providing voltage. After getting inside (NOT an easy task) the problem appeared to be a group of solder joints that had, due to heat expansion and contraction, lost all but partial contact with the circuit. When the charger would get hot, the board would flex and the circuit would break. I haven't gotten around to it yet, but I should be able to fix the problem by resoldering the offending joints.
Posted on Oct 23, 2009
  • 625 Answers
Check your computer's web site for a recall on its chargers. you may have a potential fire lurking with the one you got. I can see it getting warm, but not HOT!
Posted on May 27, 2008
Most of this series of HP laptops overheat because the coolijng fan grills get clogged with lint and dirt. You just need to get a can of compressed air and blow them out.
Posted on Sep 05, 2010
    Problem Solver:
Mine does it too my firdt charger broke and this is the new one thats gettin hot one day i went up to my room and got my cpu out from under my bed and the brick was so hot you could smell it!!! i dnt want it to catch fire so i unplug it from the wall and from the other half untill it cools
Posted on Aug 06, 2010
Generally, the battery charger has protection overcharge and overheat, how long you had charged the battery? and maybe some wrong with your charger. Maybe it can help u. http://www.my-battery.co.uk/laptop-ac-adapter/hp.htm hp laptop charger is hot!!!! - favicon.ico PR: wait... favicon.ico I: wait... hp laptop charger is hot!!!! - favicon.icottp://i.fixya.net/uploads/images/favicon.ico" alt="favicon.ico" clashp laptop charger is hot!!!! - favicon.ico L: wait... LD: wait... favicon.ico I: wait... hp laptop charger is hot!!!! - favicon.ico favihp laptop charger is hot!!!! - favicon.icoass= CY: wait... favicon.ico I: wait... favicon.ico YCat: wait... favicon.ico I: waihp laptop charger is hot!!!! - close.gif favicon.ico Top: wait... favicon.ico I: wait... favicon.ico WR: wait... close.gif
Posted on Jun 14, 2008
I installed a new battery in My HP DV4000 laptop but it won't charge. It's a 8800mah and says 11.1 volts. The old one says 10.8 volts. Any ideas?
this problem happens when the voltage of the battery is slightly less or equal or more than the output voltage of the charger u need a more powerful charger for charging that battery
Mar 31, 2010 | HP PAVILION DV4000 SERIES 30GB (4200 RPM)...
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My zv5000 has worked well for at least 3 years.
Have you cleaned or blown out the ventilation ducts and grills since you have owned it. If you haven't, there is the possiblility that the thermal paste has been baked off the processor and there has been damage done to the motherboard. The laptop will run fine with no battery installed. Get a few cans of compressed air from an office supply store and using short bursts of air, blow out the grills and all the compartments. If there is easy access to the heatsink, most likely that needs to be pulled and cleaned, as well as the processor and new layer of thermal grease applied. Remember though, if it isn't powering up at all, there could be the possiblility that the ac adapter is no longer putting out the correct voltage to power the system up efficiently. Have your power supply tested, to make sure it is putting out the correct voltage under load.
Oct 09, 2009 | HP Pavilion zd7000 zx5000 zv5000 presario...
Which replacement battery should I choose?
ebay has some great hp battery's for cheap and some places warrenty it i looked at them for mine and was the best place that i sawl
Jan 13, 2009 | Compaq NX7000 Pavilion zt3000 Presario...
HP Pavilion ZX5000
Try to check your adaptor/ charger because it might have been the cause of your battery being drained. Your wire might have been worn out. some wires inside might have been cut off. So that is why even you directly turn into AC-DC connection your PC still doesnt work. If it doesnt work replace your adopter.
Oct 31, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion ZV5000 Charger
HP has a cord that plugs into the right side of the zv5000 that is intended for use with a docking station that they sell separately. The connector has a blade with a bunch of connections, but I only use 2, power and ground. The outermost contacts are power +and-. I bought the cord - re-wired my power cord to the new cord power wires - takes some figuring to determine correct wires - soldered them up and it has worked great for 2 years - much better connector also - squeeze side tabs to plug in or un-plug. This solution was about $25 if I remember - compared to $135 that the shop quoted me to replace the internal MB power connector
Oct 17, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Laptop
please check first that does the notebook work fine on the battery mode.
if system does not work on battery mode also it is a fault of the board that would have to be replaced
if it works fine on battery, then the problem could be with the adapter
to check the same, please try using another adapter or the same adapter on another hp notebook.
if the adapter does not work on another notebook, please get the adapter replaced.
Jul 26, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavilion zd7000 zx5000 zv5000 presario 3000,R3000 Series 120W Laptop AC Adapter-360699-001 CD-ROM Drive Logo
12,836 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
