Question about Coleman Heating & Cooling
My heat pump is pumping out warm are instead of cool. I have our thermostat set to 69, on cool, and it got up to 80 degrees before I finally turned if off and opened the windows. This is my first time using the Heat Pump this spring for cooling. Not sure why I'm not cooling down.
  • 20 Answers
Its wired wrong the thermostst has wires running to the indor unit and the indor to the outdor wiring these units can be a bit complicated even for pros so use your judgement if you dont think you can handle it leave it to a pro be couse you can cause serious damage to your electronic board and that will surely cost you
Posted on May 27, 2008
Wire wilo pump
Check your thermostat wiring, it sounds like you have it set up for cooling.
Mar 07, 2014 | Water Heaters
Aux keeps coming on on regular heat is there something wrong with heat
See if it happens only when your temperature of the room is more than 3 degrees of your setpoint temperature. Since you have a heat pump, the auxiliary (electric heat strips) is use for backup of the heat pump when it can't keep up. The heat pump will run by itself if it can maintain temperature within a couple degrees. If it is too cold outside to handle the load or you set the temperature more than 2 degrees past room temperature, the auxiliary will turn on. The thermostat has a memory of how long it takes to reach desired temperature. If it goes into auxiliary mode trying to satisfy setpoint during the last call for heat, it will start the next call for heat in both aux & heat pump mode until the thermostats algorithm (timed program) allows only the heat pump to run. Not sure if you have an air to air, or geothermal heat pump. The outside air temperature will affect only the air to air system ie. when the temps drop outside, the heat coming out of your vents will be cooler...the air to air systems drops efficiency when the outdoor air drops.
Nov 08, 2013 | Honeywell TH3210D1004 PRO 3000...
Hi, I have an air source heat pump that warm the water in my koi pond, it works really well but the only problem I have is the coolest I can set the water temp is 15 degrees. My question is would I be able...
Providing its a 24V controll circuit, any heat pump thermostat would do the trick. The real trick is finding one that goes down to 8 degrees. Make sure the range goes down that low, and that it's a heat pump thermostat. A lot of Honeywell thermostats work on both conventional, and heat pump systems. You'll have to read thru the installation instructions to program it from the default conventional setting, to a heat pump setting. The manuals are quite user friendly with pictures and everything! Good luck!
Apr 11, 2013 | Honeywell Programmable Thermostat Heater
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
Hello, When I set my AC unit to "Heat" and turn it on, the air will come out warm, then after a few hours the air starts to come out cool. To make it warm again I need to set the...
It sounds like you have a heat pump. When you first turn on the system the heat strips will come on and produce warm heat (referred to as supplemental heat strips), as temperatures rise the heat strips will turn off and the "A" coil will just exchange heat to maintain temperature thus conserving energy. . Initially the temps will be around 125 degrees at the register, and drop down to about 105 after the strips turn off.
On some TXV controlled outdoor condensing units the Thermostatic Expansion Valve will stick in the cool position and require replacement this will cause this symptom. It takes several hours to do and requires a licensed technician to do as it involves recovery of refrigerants. I hope this helps
Feb 17, 2011 | Heating & Cooling
My Trane thermostat (TCONT600AF11MAA) is supposed to have 1.5 degrees of heat pump "rest" above the desired setting before turning on the heat pump. The thermometer reading does not change yet...
Friend! All thermostat is calibrated to cut in and cut off at the end of - or + 1 degree end.
Example: If you set 23 degree, it will cut off in 21 degree and cut in @25 degree. So accordingly you set the temp.
Secondly, don't set temp near to your room temp.Minimum difference should be 3 degree. If your room temp 12 degree, set at least 15 degree for heat and if room temp 28, set at least 25 degree for cool.
Hope it's helpful?
Jan 02, 2011 | Heating & Cooling
Can somebody help,why is my Central AC blows
Most heat pumps have an auxillary heat. Many are electric auxillary heat with a heat strip in the air handler. A common malfunction is for the electric auxillary heat to operate when the heat pump is set on cool. To confirm this, locate the conductor that runs from the heat sequencer to the connection on the heat strip. You will see this on the top section of the air handler. Use the clamp on part of the amp meter over that wire. If the thermostat is set on cool and the heat strip is drawing amps, it means the heat is coming on while the heat pump is set on cool. There is usually one or two causes for this, either the sequencer is bad or there is low voltage wires usually behind the thermostat or in the air handler closet that are touching that shouldn't be touching.
If this is not the case, if its not a problem of where the heat is coming on with the air conditioner, it could be a case of the reversing valve malfunctioning. The way a heat pump works is it reverses the flow of the refridgerant. For instance, many heat pumps the reversing valve is activated in cool. That would mean that there is a low voltage circuit that activates the reversing valve when the heat pump is in cool. I'm not sure what model/brand your heat pump is, Goodman and Janitrol for instance, the heat pump reversing valve is activated in cool. In any case, if the reversing valve is not operating properly, when the air conditioning is set to cool it will actually be heating. Or you could set it to heat and it may actually be cooling instead of heating. Please check these two items first and if you have any further questions, please let me know. Especially if you know of any additional problems like the evaporater is icing up or if the air handler fan is not operating when it should.
Aug 31, 2009 | Heating & Cooling
Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Dec 28, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
42 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
