I replaced the battry in my laptop and now the charge light does not go off even when it says its full it keeps trying to charge.what is wrong?
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 29, 2010
My Acer Aspire 5735 doesnt turn on
try on the laptop without battery plug in, if still didn't work, you need to get a adapter replacement for your laptop
Dec 06, 2013 | Acer Aspire 5735 Notebook
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
My laptop has problem, it is not indicates charging light and also not charging so it can't start should i replace battery ? how can i run my laptop on dirict pluged in plz, give me idea
Well It doesn't seem to me the problem of battry so replacing it is not a gud choice if you want to confirm that then take out the battry off your laptop Plug in the power pin and press the power button see if it start on direct pluging if it does then it must be your battry which requires a replacement and if does not than you power plugin socket needs to be reparied. Hopefully this would help...
Aug 22, 2010 | Acer TravelMate 4220AWLMi Notebook
PSP cannot turn on
keeping Lithium ion batteries(found in ur psp) idle for such a long time without charging may discharge them compleatly and even if you try to charge them they will not function. this seems to be a problem with your battries not ur PSP. try to get it replaced from the dealer you bought the PSP from. hope this solves your problem.. :D
Aug 03, 2009 | Sony PlayStation Portable (PSP) Console
Battery will not charge, red light blink all the time
Hello my name is Ibrahim Makki and might help you
maybe your battary date has expired or you had put the battarey on charge for long time so it blow or leave it for long time , try to buy a new one
Apr 11, 2009 | Acer Aspire One PC Notebook
Battery maintenance
you should charge fully then remove power once it is charged.
use it with battery till battery is discharged.
leaving it plugged in all the time will kill the battery.
thanks for rating.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
Please suggest me.....
the battry is dead, or the charging socket is not working try to but a full charged battry from another device and see if your device work,
of not this problem in the power section of your mobile it's an easy problem and will not cost you much
Dec 02, 2007 | i-mate JAM Pocket PC
1/3 screen is blank and loose power jack
The LCD needs to be replaced. As for the D/C Jack its the sort of laptop an engineer would have to play by ear. Or in otherwords work it out as they go along. Try removing all of the screws that you can find and be careful that you know where the screws go back afterwards. You might need to flick the hinge covers off to access the rest of the laptop. They also tend to have plastic clips all around them.
Aug 28, 2007 | Averatec 3200 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
