Question about MSI 915P Neo2 Platinum Motherboard
Laptop will turn on, but can't load recovery or driver disks and if i don't use those i get a disk read error press control alt delete.
  • MSI Master
  • 27,725 Answers
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Posted on Sep 29, 2010
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
Turn on laptop and it says "A disk read error occured press ctrl alt delete to restart
When you receive a disk error, stop using the disk immediately, and do not attempt to open damaged files. The more you attempt to use a damaged disk or file, the less likely a successful recovery will be.
You can try to recover the damaged file(s) with utility programs (such as ScanDisk or Norton Utilities for Windows, or First Aid for Mac OS X), which search the disk and attempt to recover damaged areas. Recovering damaged files or disks can be risky, however, and it is possible to make the problem worse by using these utilities. Unless you thoroughly understand the recovery software process, UITS recommends that you seek professional assistance.
The likelihood of successful recovery depends on the type of damage to the disk. Information stored on disk is vulnerable to dust, dirt, magnetic fields, static electricity, age, wear, and physical disk damage. Taking proper care of disks and making frequent backups will help protect your data.
Oct 06, 2010 | Toshiba Satelite 2405-S201 Notebook
A disk read error occurred press ctl+alt+delete to restart
May I know whether the Hard Drive is listed in the BIOS? Try reinstalling the Windows using the Windows OS disc.
Jul 04, 2010 | Dell Inspiron B130 Notebook
You have problem at the boot sector of the disk. Maybe it's hardware problem (controler, disk) or maybe it's a virus. Shut down the system and try start it up after some minutes. If it start up make a full back up just in case ......
Stelios.
Feb 21, 2010 | Computers & Internet
Press f11 to start recovery doesn't work
do you have a recovery cd or a copy of windows xp, try pressing f12 to get to a boot menu or f8, to get to a safe boot option or a last previes known good option, or some thing like this. press these options on off on off just before it goes to load the windows. try that hope it helps
Nov 30, 2009 | Cameras
How to fix a disk read error occured?
Sorry, it's time for a new hard drive.
Nov 19, 2009 | ASUS Eee PC 900 16G Notebook
More than likely you have a hard drive failing/failure.
You should have it looked at if you are not "comfortable" doing it yourself.
Jan 07, 2009 | Sony VAIO VGN-FS640W Notebook
Toshiba A55 S1064
Sounds like either 1) bad disk or 2) bad motherboard. Replacing the harddrive and restoring using the restore cd is valid and will work as long as the disk is as large or larger than your current harddisk - Fortunately it is also the cheaper of the two options.
You may lose access to the free space on a larger harddisk as the restore cd may restore the old partition information as well as the data.
May 01, 2008 | Toshiba TOS TECRA 8/2.0 40GB 128MB XPT...
Error Message Upon booting up
go to bios and load defaults. if still same thing happens after reboot. Boot from OS cd, on windows etup page, choose "R" to run recovery console. Choose OS. Run CHKDSK /R.
Feb 16, 2008 | Compaq Evo N610C Notebook
MSI 915P Neo2 Platinum Motherboard Logo
54 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
