Question about Altec Lansing ACS 52 Computer Speakers
What is the transformer voltage output for altec lansing acs 53 speakers?
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Open SKy
  • 620 Answers
SOURCE: installing the wires in the right place
Hello there!
First things first!
http://www.altec-lansing.com/downloads/ACS451_MAN.pdf
Posted on Feb 25, 2008
SOURCE: output board for Altec Lansing ADA995
I had the same problem. One day I heard two pops and the speaker, including the power light, were dead. Neither Dell nor Altec Lansing support them. They're throw-aways, unless you know a genius electronics technician.
Posted on Feb 26, 2008
SOURCE: Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
Posted on Jun 22, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
I have an Altec Lansing 340 speaker system that is not working.
There could be a defect in the connector. Check both sides for continuity.
Jan 03, 2015 | Altec Lansing Audio Players & Recorders
Power trafo altec lansing atp3
Is the label missing? All the information is printed on a label or stamped into the plastic housing. Have you opened it? Many have an internal fuse you can replace.
Jul 15, 2014 | Audio Players & Recorders
How can my laptop charger fit to computer speaker?
Please do not modify your laptop charger to power your speakers. The laptop charger probably has too high a voltage and amperage output. (USB chargers don't provide a large enough output.) The Altec Lansing ACS40 speakers need a 15V 900 mA power transformer; the coaxial power connector has the positive voltage on the center pin. The model number on the transformer is 4815090R3CT . This is available through Amazon.com and other vendors. One vendor is http://www.emtcompany.com/altec-lansing-4815090r3cac-power-supply-charger-adapter/1010666.html .
I hope this helps.
Jun 03, 2014 | Altec Lansing Audio Players & Recorders
What is the dc voltage for Altec Lansing ACS 66i
friend chk your adapters back it must be written on it....
Jan 20, 2012 | Altec Lansing Audio Players & Recorders
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Hi there My Altec Lansing 121i power transformer is spoilt. I would like to replace the same. What are the voltage ratings of the transformer Thanking you Vivek
This is one of those "it's cheaper to replace the speakers" scenarios as these units can be had for $25 new, and for even less on E-Bay.
Mar 27, 2011 | Altec Lansing 121i Computer Speakers
Hello. I have the altec Lansing acs40speakers but no power supply. What voltage do these need?
Class 2 transformer
Model: 4815090r3ct
Input 120vAC
Output: 15 vDC, 900mA
Center is positive, outer is negative.
Dec 04, 2010 | Altec Lansing Multimedia Computer Speakers
Ac adapter for altec lansing model#acs40 voltage,current & polarity
Altec Lansing Model Number A 1664
Output 15 volts DC 800ma
center Positive +
Jul 29, 2010 | Altec Lansing Multimedia Computer Speakers
Step up transformer for altec lansing atp3 that runs on 220 volts
What voltage are you stepping up to?
Does the unit run off a seperate PSU/Transformer.
Can you check your info please.
Jan 19, 2010 | Altec Lansing ATP 3W Computer Speakers
Need a driver for the altec lansing 45.1
i'm guessing you have an audio output problem.
you might not have installed the sound card driver or your sound card is not functioning.
this speakers does not come with drivers... just plug in to speaker output which is the green one. turn the speaker on and walah!
Jul 31, 2008 | Altec Lansing ACS 45.1 Computer Speakers
195 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
