Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Not cleaning - think low pump pressure during wash cycle due to durty water
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 27, 2011
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Machine does not pump all water out and after while PU flashes most of the time its just at the end of spray rinse have checked the pump and it dosnt appear to be blocked but impellor may be a bit worn...
Normally the spraying is done with a timed sequence as it depends on the program choice. So if this is a hard wash the timing will be longer.
The pumping pressure will depend on the pressure pump and water input. If low you need to check for clogging of the pump. Also residual water in the machine is due to poor drain, fault in drain pump, dirt accumulation in drain filter. remove and clean.
Jan 02, 2013 | Washing Machines
Problem with wash tower of GE GSD2200G00ww not rising up
if the tower isn't rising DURING the wash cycle it is most likely caused by one of 2 issues. 1 being too low of a water level which can be caused by low flow thru the pipes, blocked filter in the inlet valve, or a bad inlet valve. The 2nd cause can be low pump pressure due to the main food shredder screen, located below the large plastic "filter" in the rear right-hand corner, being plugged with garbage. The valve can be replaced if needed, the filter can be cleaned w/o removal of the entire unit, but if the water flow is low, you will most likely need a plumber.
Nov 22, 2012 | GE Nautilus 24" Built-in Dishwasher
Hello I get an F8 error message could you help please many thanks j
This is a failure of the water level during the whole cycle. The wash pump can be running but the water indicator is switching in and out due to not enough water, there is less than 1 litre of water in the appliance, there is an over sudsing issue (too many soap bubbles) which is effecting the WI (water indicator). This can also be caused by low water pressure from the circulation pump. Try pushing and holding the start button to reset the program and try another cycle. If it happens again you can try replacing the pressure switch that should be located behind the right side panel, its a round part that has a thin hose and a couple of wire connected to it. Hope this helps
Feb 28, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Shower keeps coming up with low pressure and water goes
think ur presure redusing velve [prv] is durty and ur hot and cold water is not balenced presure . the prv is 90% of time located in 1m radius on cold water seply to geyser look for a curtrage , unscrew clean out and put back. will fix the problem
Plz rate my advice
Jun 01, 2010 | Home
Water pressure low during the wash cycle
It sounds like there may be an obstruction in the drain. once the washer is drained, in the bottom right corner there is a basket that you can pull up and clean out. As for the water pressure being low...The machine uses a pump that supplies the wash cycle, but on rinse it uses fresh water.You may have a pump that is clogged or losing pressure good luck hope this helps
Apr 24, 2010 | Hobart AM15-5 Dishwasher
Not cleaning low pressure smells hot looks like
Sounds like the dishwasher is not getting enough water during it's fill cycle due to low water pressure on supply line or the dishwasher pump is not working correctly. Could be obstructed with food matter, etc.Hope this helps
Jul 30, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
