Question about Neff H5470A0 900 Watts Microwave Oven
The catch on microwave door has broken - Neff H5470A0 900 Watts Microwave Oven
Sharp microwave has power but does not work and door wont open
Door catch is possibly broken. Consult a qualified Sharp microwave agent.
Jul 29, 2014 | Sharp Microwave Ovens
Door won't close; spring must have come loose! how do I fix this? thanks! dmwhite64@comcast.net
The door catch may be broken. Take it to a competent service tech.
Don't try to fix this yourself as the internals of a microwave are dangerous, with high voltages even when unplugged.
Aug 28, 2013 | Samsung SMH9187ST Microwave Oven
Broken door catch
First turn the micro door upside down and shake it this may dis lodge it make sure its unplugged and rotating table is removed.If you can see the piece try tweezers or needle nose pliers but again make sure it is unplugged during any handling period!
Second UN plug the device remove its cover with phillips driver or what is needed after it is removed go to the safety switch where the piece is located remove it and shake the piece it may come out if not just replace the complete safety switch
Apr 06, 2012 | Zanussi ZM24ST Microwave Oven
I CANT OPEN MY MICROWAVE
Door catches.
One of the latches has broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 27, 2011 | Sharp Microwave Ovens
Door catch broken - door will not close. no sign of a broken piece. There was a bang and the catch just doesn't hold at all. door swings open
Door catches.
I hope that helps.
Door switches
If one of the door interlock switches is not switching properly, that can cause the turntable/light to come on even though the "Starts" button has not been depressed due to the wiring of the switches.
Check for faulty door switches and/or contaminated actuators.
I hope that helps.
Jan 12, 2011 | Panasonic NNA554 Convection/Microwave Oven
We have a Panasonic Genius Prestige 1200 W microwave. The door won't open. Tried unplugging and plugging in; that worked once, but now doesn't help.
Sounds like the door catch is stuck. Perhaps this will help;
Door catches.
One of the latches has broken off and is not lifting the dother latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Jan 01, 2011 | Panasonic NN-SD797S Microwave Oven
I pushed in the white piece where the door catches and the microwave will not run and the light will not go on
You've broken the door catch. You'll have to take off the outer casing and check whether they assembly has simply come loose or whether it's broken and in need of replacement.
As you haven't given specifics regarding make and model I cannot be any ore specific myself, but it's a very straightforward job and is usually almost identical regardless of make and model.
May 20, 2010 | Microwave Ovens
The door catch on my Bosch 8656 built in microwave has failed after only two years use. The catch itself is not broken but the spring mechanism inside the door no longer pushes the catch into the closed...
Yes, for some brands and models.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Sep 15, 2008 | Bosch Microwave Ovens
Broken Door Catch Now oven won't work
You can order parts online by entering your full model number (without dashes) here: http://www.pasc.panasonic.com/epartr Chances are the panels separate as shown in the photo I have attached below. Panel replacement can usually be done without removing the door from the microwave. In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges. I generally do not advise removing the hinges from the microwave. Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in. Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices. If you still have questions, please feel free to follow up. I appreciate your thoughtful ratings to my reply.
Aug 29, 2007 | Panasonic NN-V671S Convection Microwave...
Neff H5470A0 900 Watts Microwave Oven Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
