Question about Fisher and Paykel GWL11 Top Load Washer
Wont spin Hi ,I have a smartdrive mw model and it wont do the finl spin. Everything else is fine and it will spin on rince. Also it makes a slight thump on final rince as if its trying to start.
  • Anonymous Mar 20, 2014
    it wont rince or spin
    New Friend:
OK I have an MW511 model.
As I read my binary I am getting error code 133
x = light on
x - - - - x - x
This occurs when it comes to spin.....
- sometimes by power off wait a few minutes then back on and then forwarding thru to last cycle I can get it to spin.
But this is not always the case and is not how it is meant to work.
Generally re balancing the load does not change anything (usually careful not to over load anyhow, but some item once water logged are heavy)
Questions:
1) Does any body know what the fault issue is?
- is there an easy fix?
2) what does error code 133 mean ?
Posted on Jan 16, 2016
Mine just refused to do a final spin. 2 towels and a comforter.
Un balanced load, fixed that but it still wouldn't start. Slight burning smell. Let it sit for a few minutes to cool. Took out half the load. Then had to push down the lid lock and hand start the spin. Working fine now. We will see what happens with the next load. FP topload GL11, 2006. Been able to fix just about everything on it myself. Love it. Will be sad when it dies.
Posted on Dec 18, 2015
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 66 Answers
Posted on Nov 09, 2015
I have had exactly the same problem with my Fisher Paykel this week. Washes, rinses, drains, but won't spin on the final cycle and makes a slight thump sound.
I have the type of machine with a fanless pump, pump fixed to the underside of machine with two screws.
Solution: Carefully unscrewed the pump. Problem found: a baseball sized chunk of foul frey linty sludge, one large paperclip, one bead, one zip-pull & a pin. Removed, and works like a dream now!
Posted on Aug 27, 2011
  • 868 Answers
You have to check all the harness connections on this machine and when you realize that this is going to happen often you may want to consider tossing this in a dumpster.
Posted on May 25, 2008
  • M Aug 27, 2011
    My Fisher Paykel has been doing exactly the same thing this week. Will wash, rinse, spin through rinse, but will not do final spin and makes final thump noise. My machine has the second type of pump with no fan, attached to the base with two screws. Solution, unscrewed and carefully removed pump. Problem, a baseball sized grey linty glunk ball, one bead, one large paperclip, two pins and a zip pull. Fixed now, working like a dream!
F&P smartdrive washing machine 4 years old works fine but want the warm water hotter as it is to cold. can i adjust it?
run hot water b4 turning on machine temp are set by electronics can be adjusted slightly for just certain cycles will not make much different turn your water heater up 20 degree its what you want
Jun 27, 2016 | Washing Machines
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Fisher and Paykel Smart Drive 608 wont spin
remove the pump from underneath front right move whith clip forward the twist pump out.but you will need to remove all the water first you may a ball of lint stuck in the pump.hope this helps.
Mar 29, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
571 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
