Question about Refrigerators
Brake pull drum brakes
New shoes 1964 buick riviera, drums machined, bleed, adjusted pulls left when brakes applied
  • 1,512 Answers
Hi kincaid1964
you may also have to ovehaul the slave cylinder on the side that it pulls to . Is probably seized or jamming on corrosion. They can generally be rebuilt with a kit and returned to life again.
regards
robotek
Posted on May 25, 2008
  • Graeme Ross
    Graeme Ross Jun 05, 2008
    Hi, just a quick followup to see how you got on with your
    problem. If you still havent got it sorted, let me know, I am happy to
    do some more research and offer some more information and solutions. If its fixed...
    excellent!! A FixYa rating from you will close this unrated solution
    for me. Thanks for using FixYa. I am happy to answer any other
    questions you may have.
    regards
    robotek
How do i adjust emergency brake cable on 2003 jeep liberty sport. qith 4 disc brake pads.
Remove rear wheels and the brake rotors. parking/Emegency brake shoes are inside these rotors. Check shoes if worn, replace them Your Emergency brake is self adjustable.
OPERATION
A hand operated lever in the passenger compartment is the main application device. The front cable is connected between the hand lever and the rear cables with an equalizer.
The rear cables are connected to the actuating lever on each primary brake shoe. The levers are attached to the brake shoes by a pin either pressed into, or welded to the lever. A clip is used to secure the pin in the brake shoe. The pin allows each lever to pivot independently of the brake shoe.
To apply the parking brakes, the hand lever is pulled upward. This pulls the rear brake shoe actuating levers forward, by means tensioner and cables. As the actuating lever is pulled forward, the parking brake strut (which is connected to both shoes), exerts a linear force against the secondary brake shoe. This action presses the secondary shoe into contact with the drum. Once the secondary shoe contacts the drum, force is exerted through the strut. This force is transferred through the strut to the primary brake shoe causing it to pivot into the drum as well.
A gear type ratcheting mechanism is used to hold the lever in an applied position. Parking brake release is accomplished by the hand lever release button.
A parking brake switch is mounted on the parking brake lever and is actuated by movement of the lever. The switch, which is in circuit with the red warning light in the dash, will illuminate the warning light whenever the parking brakes are applied.
Parking brake is self-adjusting when the lever is pulled. The cable tensioner, once adjusted at the factory, should not need further adjustment under normal circumstances.
REMOVAL
  1. Raise and support the vehicle.
  2. Remove the tire and wheel assembly.
  1. Remove the disc brake caliper.
  2. Remove the disc brake rotor.
Brake Shoe
  1. Disassemble the rear park brake shoes.
CLEANING - REAR DRUM IN HAT BRAKE
Clean the individual brake components, including the support plate exterior, with a water dampened cloth or with brake cleaner. Do not use any other cleaning agents. Remove light rust and scale from the brake shoe contact pads on the support plate with fine sandpaper.
INSPECTION - REAR DRUM IN HAT BRAKE
As a general rule, riveted brake shoes should be replaced when worn to within 0.78 mm (1/32 inch) of the rivet heads. Bonded lining should be replaced when worn to a thickness of 1.6 mm (1/16 inch) .
Brake Shoe
Examine the lining contact pattern to determine if the shoes are bent or the drum is tapered. The lining should exhibit contact across its entire width. Shoes exhibiting contact only on one side should be replaced and the drum checked for runout or taper.
Inspect the adjuster screw assembly. Replace the assembly if the star wheel or threads are damaged, or the components are severely rusted or corroded.
Discard the brake springs and retainer components if worn, distorted or collapsed. Also replace the springs if a brake drag condition had occurred. Overheating will distort and weaken the springs.
Inspect the brake shoe contact pads on the support plate, replace the support plate if any of the pads are worn or rusted through. Also replace the plate if it is bent or distorted.
INSTALLATION
NOTE: On a new vehicle or after parking brake lining replacement, it is recommended that the parking brake system be conditioned prior to use. This is done by making one stop, from 25 mph on dry pavement or concrete using light to moderate force on the parking brake lever.
  1. Reassemble the rear park brake shoes.
  2. Adjust the rear brake shoes.
  3. Install the disc brake rotor.
  4. Install the disc brake caliper.
  5. Install the tire and wheel assembly.
  6. Lower the vehicle.
May 04, 2015 | Jeep 2003 Liberty Sport
Brake pull when applyed
go back to the people that did that work and holler loudly it was not fixya was it ?
Feb 12, 2015 | Galaxie Conquest 1964 Ford Galaxie 500...
I have a 67 Bonneville with drum brakes in front. It pulls to the right when braking. I have readjusted both sides and replaced the flex hoses but still pulls. Any suggestions?
Justin, Not sure if you put in new brake shoes/drums etc. Brake Pedal should be firm not spongy when you press brake down, and not spongy. Push brake pedal down hard and hold, if pedal sinks to floor you have air in lines or bad brake wheel cylinder. When adjusting the brakes , Make sure Master brake cylinder is full!...Have the tire/wheel bolted on...adjust the brakes so brake shoes cannot be tightened up against drum any further. This will center the whole assembly. Wheel should not be able to spin whatsoever...Then back off the star adjuster to loosen one click at a time while trying to spin the wheel. Make so the wheel just barely turns without the brake shoe dragging (inside assembly) on the brake drum. Do the other side so it is exactly them same looseness as other. I like to have brake adjustment so wheel turns almost completely freely with a little drag from brake shoe. Then try driving. If still same pulling...Bleed the brakes to remove air out. (Should be You tube videos showing how) While bleeding brakes, remove master brake cylinder and refill with fluid after you bleed the brake line for each time you bleed then close the brake line bleed bolt/screw. After you do left and rt front...then trying driving again. IF it still pulls....You can disassemble the whole front brake system both sides and rebuild both of the brake cylinders with kit or buy new assembled brake cylinders and replace by simply unbolting old and bolt in new. Clean all brake parts and backing plate with brake cleaner spray from auto stores One or both brake cylinder pistons inside the cylinders maybe corroded/dirty and seizing up causing one side to be doing al the braking. It would be a good time to buy all new hardware kit for each front assembly as well as long as you have it apart. With brakes removed...have brake drums checked to see if still in spec...as drums could be worn out past spec...If worn uneven ...have them turned/machined just the minimum amount to bring back in spec. Good time to replace inner and outer wheel bearings as well if not replaced for long time. Be on the safe side...Many local car clubs have members who would be happy to help you. Check your local National Street Rod Association for help! There are repair manuals for your Pontiac you can buy as well. Some people might tell you to put on expensive disc brake conversion...Don't ...unless you are filthy rich. It's Simply not needed. Good Luck. Many online you tube videos showing you what to do.
http://www.bing.com/videos/search?q=youtube+drum+brake+job+gto+pontiac&qpvt=you+tube+drum+brake+job+gto+pontiac&FORM=VDRE#view=detail&mid=EBD1745168240C7F48ABEBD1745168240C7F48ABhttp://www.bing.com/videos/search?q=youtube+drum+brake+job+gto+pontiac&qpvt=you+tube+drum+brake+job+gto+pontiac&FORM=VDRE#view=detail&mid=955B60F3A419765C311F955B60F3A419765C311F
Jan 02, 2015 | Cars & Trucks
How do i tighten the parking brake on an 91 buick park ave ultra?
check to make sure the rear brake shoes are adjusted before adjusting park brake cable. pull the brake drum off and inspect brake shoes before adjusting
Sep 14, 2012 | 1991 Buick Park Avenue
Why would my emergency brake not hold? I have installed new drums, dealer replaced cable three yrs ago and has not been tight since. I have gone back several times, and had adjustments, what else can be...
Make sure you have lots of "meat" on your brake shoes.
Emergency brakes only apply rear brakes by using shoes against the drum, that are pulled by the cable, that's attached to the emergency brake lever / pedal....and actuated by the driver.
It has to be one of those three components...may have to pull the drum and actuate the pedal / lever to see if the cable spreads the shoes and make adjustments from there.
If your back brakes don't hold...it can also cause the ABS light to illuminate...
Hope this helps...
Aug 27, 2011 | 2003 GMC Envoy
How to replace the rear break drums on a hyumdai accent gs
Brake Drums-They seem to be fastened with a nut and have bearings that need to be regreased based on the diagram found for replacing the shoes. Removal & Installation To Remove:
  1. Remove or disconnect the following:
    • Brake drum
To Install:
  1. Install or connect the following: 02-04_hyundai_accent_brake_drum.gif
    • Brake drum
    • Wheel
--- Removal & Installation To Remove:
    • Shoe hold-down spring
    • Automatic adjuster spring
    • Adjuster lever
    • Shoe adjuster by spreading the shoes
    • Shoe to shoe spring
To Install:
Note: Apply the specified grease to the shoe to backing plate and shoe to anchor plate contact surfaces.
  1. Install or connect the following: 02-04_hyundai_accent_rear_brake_backing_plate.gif
    • Shoe hold down pin
    • Return spring to the push rod while it is shortened
    • Shoe hold down spring
    • Adjuster lever
    • Brake drum
    • Wheel
Note: After assembling the drum components, pull the parking brake lever all the way up several times
Sep 30, 2010 | 2001 Hyundai Accent
Brake pedal is high and firm but brakes don't stop you quickly wh
On the drum system one end of the brake shoe acts like a pivot. Have the drums turned for sure. Before you take the drums off, loosen the bleed valve, looks like a grease nipple on the back of the wheel assembly, while someone is depressing the brake pedal. If fluid comes out tight the valve before letting the brake up and do the same on the other side. Then do the fronts. If no fluid comes out then you have an air bubble in your brake line and you need to continue to bleed the lines until fluid comes out. If fluid does come out and no air then you need to replace the master cylinder.
Sep 09, 2009 | 2004 Dodge Grand Caravan
Brake drums
the brake shoes are likely stuck in the grooves worn into the drum. You need to back off the brake shoe adjusting wheel to loosen the brake shoes.
Also, the face of the drum usually has a couple of threaded holes you can screw bolts into to help pull the drums toward you.
First, hit all the way around the brake drum with a big hammer to loosen the drum from the center hub.
Then, istall the screws to help pull the drum.
to back off the adjuster with a screwdriver:
  1. NOTE: If the brake drum will not come off, follow these steps.
  2. Loosen the brake shoe adjusting screw nut (2047).
  3. Using a screwdriver, move the brake shoe adjusting lever (2A176) off the brake adjuster screw (2041).
  4. NOTE: Move the adjustment tool handle downward to loosen the brake shoe adjusting screw nut.
    Use the Brake Adjustment Tool to loosen the brake shoe adjusting screw nut.
please give a good rating if this helps.
May 03, 2009 | Mazda B3000 Cars & Trucks
Rear brakes on a 1999 Lesabre make slight growling noise when brakes are applied . Can the brakes be adjusted?
drum brakes or disc brakes ? if drum brakes. yes but first remove the drums to be sure there is enough shoe left to adjust and to be sure there is no dirt or broken springs back there. if disc brakes no adjustment.
Mar 29, 2009 | 1999 Buick LeSabre
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
