Question about Midland LXT335VP3 Two Way Radio
How do i turn my midland lxt335 walkie talkie to silent mode. I dont want the call alert to work
ZZRuss
  • 26 Answers
SOURCE: low battery icon on Midland LXT350 walkie-talkies
Your LXT350 is equipped for using an optional rechargeable NiMH battery pack which can be recharged by inserting the AC adapter into the radio charge jack, or with the optional desktop charger.
I would make sure the radio is off, then insert the charger. Charge only for the prescribed time (no more/no less) and remove from the charger.
Charge time is initially 24 hours. Charge time is about 12 hours thereafter. For maximum battery life, it is recommend charging the battery pack when the low battery icon comes on. Remove the radios from the charger when the charge time expires.
Posted on Jan 07, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Posted on Oct 23, 2008
vrc_tech
  • 109 Answers
SOURCE: need manual for Midland 75-515 FRS Speakeashy Ultra
Howdy from South Texas and Merry Christmas;
While I did not see any radios with the model number you mentioned here is a lik to the Uder Manuals on Midlands website. http://www.midlandradio.com/owners_manuals.asp
Patrick Patterson
Posted on Dec 16, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola T5728 walkie talkie freq mismatch
Unfortunately the T5728 is not compatible with the US FRS (family radio service) frequencies. The T5728 operates between 409-410MHz. The FRS radios operate between 460-470 MHz. FRS frequencies are license-free frequencies for use in the US, as regulated by the FCC. Other countries have differing rules and thus their frequencies assigned to family usage differ.
Posted on Apr 09, 2009
SOURCE: can't get the click and back off of my walkie talkies to change
I had problems removing mine also. 1st remove the clip. With the back of the radio facing you push down firmly with your thumb and slide it off. At 1st I didn't think mine removed but after some extra force I was able.
Posted on Jan 30, 2010
My little tikes red walkie talkies aren't working. One has static, the other is silent. What to I do?
check the batteries. When left on, the batteries will continue to dis- charge (and what kid turns things off?) and eventually ruin the battery.
Jul 10, 2015 | Walkie Talkies Radio Communications
I need a downloadable manual for midland walkie talkie G-300M to know how to use all its features
Download your manual from here: http://www.manualslib.com/download/103186/Midland-G-300.html
Feb 23, 2015 | Midland Radio Communications
My midland gxt quit working,why is that
is there power across the charger contacts ?
get a volt ohm meter & check for starters
usually if you leave the wall wart plugged in all the time they burn out & fail
Dec 25, 2014 | Midland Radio Midland Gxt795vp4 36 Mile...
Constant static midland walkie talkie
Doesn't it have a squelch adjustment?(it allows you to adjust sensitivity of the "gate" on the receiver).Turn the knob counter-clockwise until it just goes quiet.The receiver will be silent until a transmission is detected.
Oct 07, 2012 | Midland Radio Communications
I lost my manuall for my GXT walkie talkie
Look online for the manual, I found my refrigerator manual online,
Jul 04, 2012 | Midland Radio GXT760VP4 - X-TRA TALK GMRS...
Motorola walkie talkie randomly cuts off
buy professional radios and you get better battery contacts
dont go to work with child's toy
Mar 22, 2012 | Motorola Walkie Talkie 2-Way Radio
One of my midland lxt 420 walkie talkies wont charge!!!!!
If it has rechargable batteries in it like mine does, the batteries have probably lost all of its life.. you can replace them.. if you dont have batteries, you could have a loose wire inside the walkie talkie that wont let it charge..
Jul 29, 2009 | Radio Communications
Hello i have a Uniden GMR-325 (7 Channels) Two Way Radio that....
Hi Zachary
I predict that you have trouble with only one unit.
Try to find some one with either the same units ( on same Frequency of course) or a receiver that also covers same Frequency and transmit on one GMR then the other to esablish which unit is faulty!
The faulty unit should then become apparent, the buzzing could be caused by transmisson of the faulty unit, check all Antenna connections, even change antennas over on testing as prescribed above,
good luck John.
Apr 05, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Walkie-Talkie wont work and the Outside buttons wont work.
This is called the PTT buttons Back housing assembly: Open your phone make sure the wire is attached correctly: If the wire is attached correctly you need a new back housing. www.cdphonehome.com Nextel Repair Parts
Oct 30, 2006 | Nextel i860
Midland LXT335VP3  Two Way Radio Logo
110 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
