Question about Garden
Looking for manual for efco 8350 strimmer will start but wont keep running may be carburettor where can i get download manual help!
  • 246 Answers
SOURCE: Need to find Tanaka tbc Grass Trimmer,carburettor service manual
Hello
If the Carburetor OEM is a Zama, then
>>You can View a Breakdown/IPL of the Carburetor and Get Technical Information on Zama Carburetors at this Site Addy; http://www.zamacarb.com/tips.html and Select the Technical Guide.
If the Carburetor OEM is Walbro, then
>>You can View a Breakdown/IPL of the Carburetor at this Site Addy, http://69.16.165.8/ and Select Service & Aftermarket. Now Select Aftermarket Parts and Service. Now Select the OEM (Tanaka). Now Select Trimmer. Now Select your Carburetor (?) from the List Provided.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • 3230 Answers
SOURCE: MANUAL OF UNIDEN CAR NAVIGATION SYSTEM GNS 8350
Well, you download your manual from the below link -
http://www.uniden.com.au/resources_main/pdfs/GNS8350_OM.pdf
Just copy and paste that link to your web browser.
Good Luck!!
Thanks
Posted on Jul 28, 2009
  • 125 Answers
SOURCE: Manual for Efco FL6 Chain Sharpener
The chain saw chain sharpener is an "efco Industries" chain sharpener that was made in Italy. Type # 136 & LR# 36941 have a good day please rate bama46, thanks
Posted on Aug 22, 2009
hunter19_46m
  • 7482 Answers
SOURCE: EFCO petrol strimmer - can anyone tell me how to
If you need to clean the filter, remove it from the fuel tank and blow compressed air into it, otherwise you may have to do the following:
Sounds like you will need to clean your carburetor
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 24, 2010
  • 2239 Answers
SOURCE: husqvarna strimmer 132 connection
This is an old machine made by Mariama under licence to Husqvarna, the grommet in the tank takes two pipes and was part no. 531002411, try the web for a seller.
Posted on Aug 14, 2011
My efco stark 4400t strimmer revs so high it cuts out.
Turn the high side adjusting screw CCW a 1/4 to 1/2 turn.
Feb 25, 2015 | Garden
Fuel mixture for efco 8300 strimmer
standard ! 100-130 ml oil for 5 Liter gasolin!
Apr 04, 2014 | Garden
RYOBI 2 stroke strimmer starting on choke but not running off choke
First is to control gaskets (best way to do that is carefully tighten the 4 nuts slightly from the cylinder and the 2 of the carburetor somewhat because of possible gasket leaking to control second thing remove the exhaust(muffler) look the piston that its smooth (no grooves on the surface of the piston or the springs to see ) if all was ok until now you have luck, next step is carburetor clean and service it fuelhoses not leaking or primer bulb tankfilter tankairiation. i think first is that its having loose some compression by a too poor fuel mixture but more on a to bad L ( in most case +H was having a too lean adjustment ) or there was working with full trottle too long in a row without intermediate break, the most problems on this kind of saws leaking primerbulb tankairiation problems ( fuel canals special on models with a zama carburetor)
Jun 12, 2017 | Garden
Free user manual download for EFCO chain saw sharpener type FL6
I found the most helpful manuals here that are very similar to the chain grinder you are looking for.
http://www.tiltonequipment.com/product-lines/total-and-tecomec/tecomec-manuals/
Jul 13, 2011 | Garden
they were in/out.
May 24, 2010 | Garden
Aug 22, 2009 | Garden
Good Luck!!
Thanks
Jul 28, 2009 | Uniden GPS
I have a rhobi strimmer only 2 years old wont start
I presume this is a petrol one. The fuel can dry in the carby and stop the unit from starting. Use fresh petrol.
I am not sure about the ryoby unit, but if there is a air filter, take it out and dip it in petrol, then try to start with the normal proceedure in the manual.
Jun 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Require a manual for an ''efco'' chain sharpener.
There are no "efco" chain sharpeners at Northern Tool or at efcopower.com. There is a Chinese made grinder with the Northern Tool name on it. It is a lessor quality copy of an Oregon model 511A. It is such a good copy that parts and the manuals are interchangable. The 511A manual can be downloaded here: http://www.oregonchain.com/pdf/accessories/511AManual_3Lang.pdf
Lou --> -->
Apr 04, 2009 | Northern Tool Garden
Garden Logo
179 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
