Question about E-Machines T2682 (000002965) PC Desktop
Front panel leads
The 3 leads popped off mobo the mobo markings say "front" "panel" and "hdk" but are arrangeed 2x2 in row so its ambiguous as to placement
is there a pic for orientation?
which of the 3 markings indicates the switch 'front' or 'panel'?
thanks
jack
  • drjack3 May 25, 2008
    this was very hlpful I couldnt open the link tto the manule but i was able to dwnld it and voilla I was able to reconnect thee leads
    thanks again
    Brigadier General:
  • 6,966 Answers
Pls confirm if your eMachine T2682 is using an Intel D845GVSR motherboard. If yes then this zipped pdf document is its manual. The different connection points is shown in p.14. With respect to orientation, for the switches - none, for the LEDs - there is a polarity orientation/requirement. The correct way is to use a continuity tester, determine which pins are tied to the ground and which are the anode/cathode of the LEDs. The short way is to power the unit and test plugin the LED's connectors and check which way they will light up. Just be sure to do it real quick so as not to burn them if the polarity is reversed. If it does not light up, reverse.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 25, 2008
  • Louie  Role
    Louie Role May 26, 2008
    Glad to be of assistance and appreciate the rating.
Need pinout for A8N-LA front panel to mobo
Mike,
Going to detail it out, so those needing this info in the future also, can use it.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00647121&dlc=en
Scroll towards the bottom of the page for the motherboard illustration, and photo.
The front of a desktop computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
In the illustration, and as the motherboard sits in your computer case, the Front Panel is at the Bottom/Right corner.
In the Illustration it is F_PANEL1.
In the photo it is the black rectangular block, with 9 contact pins.
Two rows of pins.
4 on the Top row, 5 on the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side on the Top row, going across to the Right;
Pins 2, 4, 6, and 8.
Starting on the LEFT side on the Bottom row, going across to the Right:
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a RST SW is used.
C) Pin 9 is N/C.
Not Connected. Pin is reserved for factory use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10. Just a blank spot.
Regards,
joecoolvette
Jul 24, 2012 | ASUS P5PE-VM Motherboard
57wv600 blinks 7 times, no picture, or blue for few seconds
1. Remove the 5 screws from behind each speaker
2. Grasp bottom center of plastic panel and "pop" forward. Swing upward to remove.
3. Remove 4 screws from the wooden panel in center.
4. There is a "black box" in the very front of electronics. It will have torque paint on the 2 rows of 3 screws. top row is labeled "focus"
MY TV would go green before going black. Volume still worked.
5. I turned the center bottom screw (marked "green") appx. 1/8 to 1/4 turn COUNTER clockwise.
Plugged TV in and it works fine.
Oct 08, 2011 | Sony KP-57WV600 57" Rear Projection...
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
Jan 23, 2011 | EliteGroup P4M800PRO-M478 Motherboard
I have a gigabyte ga 81865gme775 mother board, can you give me the front pannel connection details
hello jknr09
my name is ausi
i can not find your motherboard on gigabyte web site. however the boards nowadays are standard as far as front panel header goes.
on gigabyte mother board you will see the hedae as two rows of pins like this.
the bottom row first 4 pins are the speaker pins. the next single pin is void the next two are reset switch. the last two are hard disk lead.
the top row first two pins are message lead (usually not used). the next two pins are power switch exactly opposite the reset switch.
the power lead connection on gigabyte boards are a three pin header next to the front panel header.
hopefully this is helpful.
please vote for me
Jan 20, 2011 | Intel Motherboard
I can't find where the connections of the front panel are on the motherboard or where they go?
The eMachines T2893 desktop computer uses an Inte G845GVSR mobo. (MOtherBOard)
Intel Support>D845GVSR>Motherboard Manual,
(Intel's name - Product Guide),
http://www.intel.com/support/motherboards/desktop/d845gvsr/sb/cs-008823.htm
I would like you to left-click on the top file.
Click right on - Product Guide - PDF, in blue.
(File name underneath it is -
File Name: D845GVSR_Product Guide_English.pdf )
May take up to 30 seconds, before you see the first page.
(You will be staring at a blank screen until the first page comes up. The file is downloading in the background)
Took 5 seconds before I saw the first page, and an additional 12 to fully download, using a medium speed DSL connection.
The Front Panel header on the mobo is shown on Page 31. (C on the illustration. J9G1 on the mobo)
The Front Panel connections are on Page 32.
Barring that you cannot download this PDF file, or do not understand the manual, I will detail the Front Panel header connections.
Orienting the motherboard so we are both looking at it the same way;
The Processor is at the top, the ram memory slots are to the right side of the mobo, and the white PCI slots are to the bottom.
There are three PCI slots. The one closest to the Processor is PCI 1.
The one closest to the edge of the mobo is PCI 3.
To the far right of PCI 3 is the Front Panel header.
It's the header located closest to the Right side of the mobo, and the bottom edge, and is directly below the
CMOS battery.
There are two rows of pins.
Four across the top, Five across the bottom.
The top row of pins are numbered Evenly.
The bottom row of pins are numbered Odd.
Starting from the Left side of the mobo, going to the right, on the Top row,
Pins 2, 4, 6, and 8. (There is No 10)
Starting from the Left side of the mobo, going to the right, on the Bottom row,
A) Pins 1 and 3 are for the Harddrive Activity LED
If you have a wire with a + sign on it (Positive) it goes to Pin 1.
B) Pins 2 and 4 are for the Power On LED.
(Pin 2 to the Green LED lamp, Pin 4 to the Yellow LED lamp, if applicable with your computer)
C) Pins 5 and 7 are for a Reset switch. (If applicable)
(Pin 5 is Ground)
D) Pins 6 and 8 are for the Power On switch.
(Pin 8 is Ground)
E) Pin 9 is for the +5 Volt power.
(You are following Anti-Static precautions, right?)
Have any questions just post in a Comment.
(Believe upper right of your page)
Jun 13, 2010 | E-Machines T2893 PC Desktop
Theirs no indication where about to put the power switch,power led,reset switch and HDD led in motherboard acer veriton 3600g?
The connections are printed on the edge of the MoBo under the pins. With the back panel on your left the front panel connector pins are on the bottom right bottom row should be (from left to right) PWRLED PWRSW
The row above HDDLED RSSW
Apr 09, 2010 | Acer Veriton 3600 (V3600GT00150) PC...
I have desktop C2480 emachines with AMD athlon XP. The problem is when i turn on the CPU the leds never on. I opened the CPU and i saw the 3 connectors from the mother board disconnected thats 3 pair of...
Ok these go on a small dual row of Header Pins on the Motherboard, Generally near the front or side of the MB. They may be marked the same as on the leads. Otherwise you will have to look in the manual to see what one is what. I wonder how they came off?
Feb 06, 2010 | E-Machines C2480 PC Desktop
Would like to find the pin sequence for the
black green white red inside row nearest battery,starting from the front facing end.
Mar 13, 2009 | Gigabyte GA-8SIML Motherboard
Front Panel wireing Dia for 8328E required
1 VCC 2 VCC
3 USB0 4 USB1
5 USB0+ 6 USB1+
7 GND 8 GND
9 Key(no pin) 10 USBOC
Jan 30, 2008 | Matsonic 8328E (MS8328E) Motherboard
It wont turn on
Hi, there will be a row of pins at the front of the mobo,use a torch and if posible a magnifying glass to study them. Along side you will see the markings, pwrsw, hdd, rsw etc. the leads from your case will have similar markings. If the led does not work then just reverse the plugs on the pins. Dont worry if you have things the wrong way around no harm will be done it just wont work. Regards mistyman
Sep 24, 2007 | MSI MS-6159 Motherboard
E-Machines T2682 (000002965) PC Desktop Logo
110 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
