Question about Braun 360° Complete 8985 Electric Shaver
How does one release the bottom of the braun BS 5301
4 Suggested Answers
SOURCE: hi,
While holding the neck, pull up hard on the charging piece with the blue button.... You will not break it, it will go right back in after...
DO NOT try to remove the whole neck, just the button piece will come up, an inch or two (NOT OUT COMPLETLY) The wire will only allow you to pull it up 1"-2" so dont try to remove it....
Then look inside and you can see a spring, it's not attached to anything it's just resting in a hole. Pull it out and then push the top charging piece back down till it clicks in...
Now it will stay down on its own... I had the same problem and this work around solved it.
Posted on Mar 28, 2011
vetteman3002
  • 2299 Answers
SOURCE: hi, My braun bs 5301 does
Check to make sure that the shaver and the charger are clean. It is not locking in because there is something that is not letting it go down in far enough. You can clean it with canned air.
Posted on Nov 05, 2010
SOURCE: hi,
How do you change batterie in thermoscam ear meter
on the side with the screen about 3/4 of the way to the bottom should be a tiny hole put a pen in it and push down to release the lock and open
Apr 07, 2013 | Braun IRT3020 Thermoscan Ear Thermometer
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
Mar 16, 2013 | Skytech 5301 Fireplace Remote Touch Screen...
Can you change the temp reading from F to Celcius on a Braun Thermoscan 6014?
Turn off the thermometer
Press and Hold the L/O Button
Continue to hold the start button when the F or C display appears. Watch for these displays to cycle over the display window.
Release the start button when the F display appears on the screen.
5
Listen for a beep and watch for the Braun ThermoScan ear thermometer to shut itself off, indicating that you changed the temperature scale to Fahrenheit successfully.
6
Follow the same procedure but release the start button when C shows on the display to switch from Fahrenheit to Celsius.
Feb 28, 2011 | Braun Health & Beauty
I got a 810-5301-c but do not have the operators manual
You should be able to access it from the following website
http://images.brinkmann.net/Docs/Pdf/810-5301-C.pdf
Mar 28, 2010 | Brinkmann 810-5301-6 All-in-One Grill /...
Hi, My braun bs 5301 does not lock my braun 7630 shaver in anymore. at the top where it clicks into the bottom of the shaver, its not actually clicking in and now it doesnt charge or clean unless i hold it...
Oct 23, 2009 | Braun Syncro 7630 Electric Shaver
Oct 23, 2009 | Braun Health & Beauty
Base floods with solution during cleaning cycle
OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
Nov 04, 2007 | Braun Flex XP II 5790 Electric Shaver
Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
Nov 03, 2007 | Braun Flex Integral Shaver 5520
Opening Braun 2540
Yeap! I just did it violently... :S But luckyly didn't break anything. Anyway, the right way: First screws of course. Then you can open it a little bit, and you can see a white part at the bottom. It moves sideways and releases the cover. Hope you can make it easier than me!
Mar 15, 2007 | Braun 2540 S Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
239 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
