Question about Whirlpool Dryers
I Have a whirlpool dryer and the heater coil shut off and comes on, seems like it gets to hot and it shut off in till it cool down and it turns back on, is this suppose to do that, it seem like it take alot more time to dry. is the coil suppose to stay on the hole time? is there a temp sensor i need 2 change? if so where is it and what dose it look like? thxs
  • 1 more comment
  • billysbills1 Sep 29, 2010
    thx 4 the info, i ck the lent trap and did what u said by taking off back left cover, found very little lent near blower or in cover, i have a mod# WED5300SQ, looks very similar as the pic u sent. I live in a apartments, and the air duct that go outside gose under the building and outside, could that be needing 2 b cleaned out and could that b the problem y its not drying as good. thxs.
    ok, thank u again, i will get the apartment 2 clean the hose going out, i will run 1 or 2 loads without the hose hooked up 2 see if that make a diffents.
    very helpfully thank you!!
    President:
  • 1,218 Answers
Good day,
It is designed to go off and on. On normal heat setting, when the control thermostat reaches 155 degrees it shuts the heater off and the heater stays off until it drops to approx. 125 degrees then turns back on.
If it is taking too long to dry, then it is almost always lint build up in the vent system or the dryer itself.
First test should be to run the dryer with the vent hose off. If drying time becomes normal,then clean or replace the vent system. If no better.......
You gave no model number, but with the standard style, it is not uncommon for the area around the blower wheel to pack up with lint.
To clean it, you will need to remove the lint filter, and the 2 screws under it. With a screw driver, pop up the front of the top lid one side at a time, and rotate up to a vertical position.
Go to the back of the machine, and remove the backing cover.
You will see something like this.
The housing on the left covers the blower wheel and housing.
Remove the screws holding it in place, and pull away and up as far as it will go.
Check that area for excessive lint. It should be obvious. Clean as needed, and check the lint filter. If the lint filter won't clean, replace it with a new one.
There are other limit safety thermostats in that back area, but usually they simply fail, causing a no heat situation.
Posted on Sep 29, 2010
  • John Hall Sep 29, 2010
    Good day again,
    If the vent run is too long, it will definitely reduce the airflow, causing your problem. This issue comes up frequently on apartments and condos.
    Once again, if you have the ability to remove the vent hose from the dryer and try it for one or 2 loads, that should give you the answer.
    The apartment management should be responsible for the vent system whether it's too long, or plugged up.
    If step one fails to work, I would talk to them and try to resolve it.
    As I said, this has been an on going issue with apartment complexes and multi-family dwellings.
    If you've covered all the steps I've outlined with no improvement then advise them. Some complexes are great to deal with while others .........
Coils lights up but no heat goes up to drum
if your heater coil is working
dryers have a cool down cycle built in
the coil heats shuts down
and drum rotates till end of cycle
Oct 13, 2016 | Dryers
Old whirlpool freezer door left slightly ajar.light on inside.door won't seal. Rubber on door warm.
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
the reason the outer side of the door seal area is getting hot is the compressor is over heating, probably the condenser fan motor to your compressor is bad.
It should be a little warm but not hot. they don't use heaters anymore ( some older models still use heaters) around the doors, instead they use the condenser coils to remove condensation and moister, you might want to check your condenser coils on the bottom or back of fridge to see if they need cleaning
If the condenser coils/condenser fan are all plugged up they need cleaning and/or the condenser may fail or has failed..
The ones that use an electric heater will have an "energy saver" switch that will turn it off.: God is the reason I give you free advice so God is good!
May 03, 2015 | Whirlpool Refrigerators
Will the very warm to touch problem with middle bar that doors close against on Whirlpool side by side also happen if you run it with the ice chute cover off overnight?
Apr 16, 2015 | Whirlpool Refrigerators
The igniter glow bar gets bright and hot on the first burn in the drying cycle, however on subsequent urns it doesn't glow bright or long enough to ignite. What's up?
The ignitor is either going to be good or bad. If it fires off it is fine and if it is shutting down then the flame sensor is also working. That tells me your coils are weak and old.
Here is how it works and why I believe you need to get new coils: When the dryer is cool first thing in the morning the initial start up the fuse and control besidethemobilian_2632.jpg
it allow power to the gas assembly, the flame detector/sensor allows power to get to the ignitor and it begins to glow. 1800 degrees is what that baby puts out and at that point the flame sensor bi-metal bends and shuts down the ignitor. The holding coil and secondary coil will then have enough power partially because the ignitor is off and partially because the ignitor is now acting as a thermocouple. If for some reason the gas did not ignite then the ignitor would cool down and shut off the gas. themobilian_2633.jpg
When the temp inside the drum gets to 160f that control beside the fuse shuts off the gas assembly, IF it don't shut down the gas then that fuse melts and shuts down the power to the gas assembly but it doe not shut down the dryer. The fuse is good though because you are getting power to the gas assembly AND the gas assembly is shutting down at 160f. The dryer keeps a tumbling around till the temp in the drum drops to 105f at that time the dryer wants another blast of hot air, trouble is the coils have gotten hot now, the ignitor is doing its thang, the flame sensor is doing its thang, the control is doing its thang. The only thing that ain't happening now is the coils ain't allowing gas to come out. Replace the coils and party on! More here
Jul 18, 2011 | Kenmore 400 6942 Dryer
If the furnace will run one cycle after manually turning on and then shuts off and does not turn back on automatically what does this mean?
dirty a coil,dirty filters,lack of air flow ,too many registers closed will trip high limit.furnace will run again after cooling down and turning power off and back on.till limit gets too hot again.
Dec 20, 2010 | Coleman Propane Forced Air Heater...
When the dryer is cold the heater flame will
The heating circuit is working perfectly except for the solenoid coils as indicated by the occasional glowing of the igniter but no gas is ignited. A gas valve closes as the solenoid coil weakens as it gets hot and does not open until it has cooled down. Replace both gas valve solenoid coils to get the dryer back into proper operation. The solenoid coils are part numbers 694539 and 694540 but also can be purchased as a kit here.
Apr 27, 2010 | KitchenAid KGYS850LT Gas Dryer
My whirlpool dryer heat does not stay on. when i first start it , its hot then the heat turns off. it continues going with no heat
With the limited information you gave I will assume this is a gas dryer that the flame starts for a minute or so and then shuts off. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Oct 09, 2009 | Whirlpool Dryers
Freezer not cold enough to make ice and fridge cool not cold
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Whirlpool Refrigerators
I have whirlpool dryer that the heat seems to kick on and off it is gas dryer
If heats for a few minutes then cuts off (heat) , then the 2 coils on the burner valve are probably bad . OR check the vent hose to the outside for good air flow . Sometimes , a dryer is pushed too far back , and it kinks the vent hose . If coils are bad , when dryer cools down , then restarting , cool coils will heat again for a few minutes , then stop heating till they cool off again .
Aug 01, 2009 | Dryers
Whirlpool dryer the heating element will not shut off. I suspect a thermal fuse but took them in and they said they were okay. I am going to check and see if the element goes to ground on the case as...
There have been many cases in recent months where the heater coil is shorting to the case. In many cases, this issue will only appear when the heater gets hot. If the dryer is getting hot when not running, replace the heater even if it appears good when cooled down. You received good recommendation....
If you need further assistance, let me know
Regards,
reg501
Jul 07, 2008 | Whirlpool Dryers
Dryers Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
