Question about HP OfficeJet K80 All-In-One InkJet Printer
Can fax anywhere except one location - HP OfficeJet K80 All-In-One InkJet Printer
  • bfe4 Sep 29, 2010
    yes this is correct, thank you.
    President:
  • 2,777 Answers
Hm, ok, so to clarify you CAN send faxes to any number, except for one particular number you are trying to fax?? That means it is the destination fax that is having issues, not yours. Please clarify though, is this what is happening?
Thanks
Tim
Posted on Sep 29, 2010
  • Tim Grayson
    Tim Grayson Sep 29, 2010
    Ok well that is most certainly not a problem with your fax machine. You will want to call whoever it is that you are trying to fax to and tell them their machine is not working with your fax. See if they have an alternate number you can work with... If not, maybe you can email it to them? I can tell you for sure though it's not a problem on your end, if anything your two fax machines are just incompatible, and there is nothing you are doing wrong.
    Thanks
    Tim
Faxing
Maybe they gave you the wrong number. Call the number from a regular phone and listen for fax tones.
Feb 16, 2010 | Samsung SF-560 Plain Paper Laser Fax
Help me please!!
I dont work on them but have you ck your ac power supply it could be bad.
Sep 18, 2009 | Computers & Internet
NG Poor line condition whenfaxing
If this is truely an issue involving poor line conditions you can try using a Line Noise Filter which you can get at most Radio Shack locations. Should cost about 14.99 or so. This could be caused by a loose connection in your home/office wiring or a loose connection at the switch box or anywhere along your line all the way to the tandum. If you actually hear static on the line have the telephone company do the work. Call in a bad connection issue and ask for a line test. If there is a grounded line somewhere that will detect the fault and they can better isolate where the problem actually is located.
Sep 08, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Just wondering on how to set up so u can get faxes from all area codes not just one
You will automatically receive faxes from anyone with a compatible fax anywhere in the world. You may be confusing receiving as you had to enter your area code in setup to send faxes. That does not keep you from receiving (or sending) anywhere you like.
Aug 11, 2009 | Lexmark X5495 All-in-One &USB...
HP officejet 6310 cannot fax
did you have fax service on the line?
Jan 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Scanner malfunction
JTuohey
I had the same problem and just successfully repaired. Uninstall driver and reinstall. Worked perfectly!! Good Luck!!
Jun 23, 2008 | Dell A960 All-In-One InkJet Printer
How to change Baud rate on MFC-8640D
2 identical fax machines cannot communicate at 2 differant locations about 30 miles apart. the machines operate properly faxing anywhere else. DSL has been taken off the line at one location and the fax line has been fed from a differant location as well on good clean testing cable pair
Apr 25, 2008 | Brother Office Equipment & Supplies
Even vertical lines on fax/copy
TYPICALLY SF900 FAX USES A DIFFERENT CIS SCANNER , THSI SORT OF INDICATION IS EITHER SMPS BAD OR CIS SCANNER BAD. HAPPY FAXING OMNIRESENT
Sep 16, 2007 | Panasonic KX-FHD331 Plain Paper Thermal...
Stretched text on faxes
In my experience, this type of problem is on the sender's end and not the receivers. We have sent faxes before and while they are sending, the paper on our end misfeeds and the received copy on the other end is stretched and unreadable. One way to determine this is to have a few different people from different locations send you faxes. If all the faxes have this problem, then it is a good bet it is a problem on your end. If not, then it is probably a problem with this particular sender's fax machine. I hope this helps.
Jul 27, 2007 | HP 1040 Plain Paper Inkjet Fax
HP OfficeJet K80 All-In-One InkJet Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
