Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
Top t section broken - Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
I have a Konica c450 and It is telling me section not closed properly when paper is put in top section but it is closed.
which section the cover on the right or the left of the doc feeder? if so check that some did not brake the tab that tells the copier that the cover is closed or that the senor that the tab acturates is not dirt or broken or bad
May 15, 2017 | Konica Office Equipment & Supplies
I have a late 70s 28hp Mariner Outboard, appears shift linkage has broken just below the motor where it connects to the rod that goes to the foot. How do I repair it with out moving the motor?
talk with a mariner service center
get a workshop manual for the outboard
with many outboards the selection rod comes apart with the bottom section as if you were replacing a water pump
see if you can undo the top section and let it fall out the bottom or lift the broken section out past the motor
talk wit a service center first and get some ideas
Nov 11, 2016 | Cars & Trucks
My 01 duramax has broken 2 power steering pulleys in a month.Any ideas?
Check that the v section of the belt is correct if it is a v belt drive. If the top section of the belt is too wide for the pulleys there is extra load placed on the edges of the pulley flanges. A correct fitting belt should be level with the top of the flanges or just feel able above the flanges.
Oct 08, 2014 | Cars & Trucks
My Kenmore Coldspot will not stop running and is getting too cold. The food in the fridge is freezing. Any suggestions to help me pinpoint the issue?
Either you have a cold control issue or a broken damper allow too much air into that section. I would look into the air control section, top left of the refer section. If the door doesn't close it will cause a freezing effect with this section to occur. I hope this helps.
Aug 31, 2014 | Refrigerators
Kenmore elite top loader washer rattles
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2010 | Kenmore 22422 Top Load Washer
The Oasis HE top load washer Model 110.27062601 gets out of balance while spinning.
Jan 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite top loader skakes bad it is level drum sets to the left off balance bad
Dec 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Kenmore top loader 25811 Drum is off balance
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!
Feb 17, 2009 | Kenmore 25842 Top Load Washer
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
16 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
