Question about Panasonic KX-T7630 Corded Phone
HOW TO CHANGE TIME IN PANASONIC KX-T7630 AND HOW TO CHANGE DAY MODE AND NIGHT MODE TIME
  • 3 Answers
SOURCE: Change Time
Press 'Prog' then press star key twice, then enter '1234', then enter '000', will get you to Date & Time Set, then press 'enter' button (bottom right hand corner of phone), this will then allow you to change the date and time accordingly.
Hope all goes well
Tess, Australia
Posted on Feb 01, 2008
  • 9 Answers
SOURCE: setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
Posted on Dec 06, 2007
  • 6 Answers
SOURCE: kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Posted on Feb 12, 2008
  • 6 Answers
SOURCE: How do you change the
  • Press 'Prog' on the LCD screen
  • Enter ** (Star, Star)
  • Enter password (usually 1234)
  • Press 'Next' on the LCD screen until you see 'Date & Time Set'
  • Press Enter
  • You should now be able to change date and time
  • The arrow icon on the LCD screen allows you to move forward and back (press 'Shift' on the LCD screen to change the direction of the arrow)
  • Press SEL+ to change things like month and use the number buttons to change year, day, hour and minutes.
  • Press Enter and then pick up the handset and hang up to complete procedure
Posted on Dec 05, 2008
SOURCE: how do you set the time
To change time on the KX-T7630 switchboard (using the TDA 100).
Press Progam or pause
Enter **
Enter your system password.
press cursor down one level - you will then see set date and time.
To exit the programming mode at anytime, lift the handset.
Hope this helps.
CM
Posted on May 20, 2009
How do you switch out of night mode on the panasonic KX-T7630 phone ?
It may work on all phones, but from the main phone on the intercom dial *780x where x = 0/1/2/3 for Day/Night/Lunch/Break.
It can be programmed to work from any phones in the sysetm by class of service.
Carl
Dec 07, 2009 | Panasonic KX-T7630 Corded Phone
Change how many ring for day time recording to pick up
I can answer it, but it requries programming access to your system.
Better to call your installer/programmer who will know how he set it up.
It's an intercept timing issue.
Carl
Sep 01, 2009 | Panasonic KX-T7630 Corded Phone
How do you set the time
Enter **
Hope this helps.
CM
May 19, 2009 | Panasonic KX-T7630 Corded Phone
How do you cancel night mode on the KX T7630? Or
If it's enabled on your phone, on the intercom dial *7800 That puts the system in DAYS. *7801 puts it in NIGHT. By default extension 101 or the main phone has access to it. We turn it on for everybody in most offices by Class of Service options.
Carl
Apr 27, 2009 | Panasonic KX-T7630 Corded Phone
Day message
Yes absoulutely but this would be up to the tech who installed your phones system. He would need to connect to your panasonic system and change the features from the brain.
Dec 10, 2008 | Panasonic KX-T7630 Corded Phone
Switching phone to night mode on dfferent number
If you can dial *7801 on the intercom from your phone and it puts the system in night mode, then you can program a button to do the same. It would be better if you go to the original phone where the buttons worked and read them (PROG press the button and write down what it says).
Now go to your phone, press PROG the same button and dial the code you wrote down. In the simplest, you put 593 ENTER for DAY/NIGHT. Then PROG to exit. If you want more options, then 59x can be 0 for DAY/NIGHT/LUNCH/BREAK 1 for D/N/B 2 for D/N/L.
Every time you press the button, it will toggle to a different setting and the display will show it.
Carl
Nov 13, 2008 | Panasonic KX-T7630 Corded Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
Night mode
I find that if you press line 24, you can scroll through Nigh Mode, Lunch Mode and Day Mode....Hope this helps
Dec 10, 2007 | Panasonic KX-T7630 Corded Phone
Stuck on Night Mode
Your phone can work on different Panasonic phone systems that program differently. I would need to know the model number of your phone system to look up specific information.
Until I get that info from you. Most systems can only be turned on and off from night mode at one phone station (usually the operator) but others will let you program a programmable key on any phone to do this. It's also possible to enter a function code from any phone on some systems.
Does it say Night Mode on a display? How do you know it is in night mode? If it is on a display, is it on all the displays or just one? If just one then that is the phone that can turn it off.
Nov 19, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
311 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
