Question about Premier Kitchen Ranges
The gas oven with electrical ignition does not go on. The gas burners on the stove top do.
  • Premier Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Sep 30, 2010
Testimonial: "The repair man is coming tomorrow and that sounds like what it is. Thankyou!"
The electric panel on my smooth top stove just went out with a popping sound rendering the oven unusable but the stove top burners are working.............what could have happened and is it worth it to get...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 21, 2010 | Kenmore 95423 Stainless Steel Electric...
Stove top ignitors do not ignite but oven does.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Gas stove with electric ignition (oven stopped working)
the electric ignition is bad and needs replaced in oven. I had the same problem a few months ago and it was the ignitor for the oven. if replacing it yourself, be very careful with ignitor, it is very fragil. do not touch ignitor itself, hold on to it by the base of it. they are not that hard to change.
Jan 31, 2010 | Kitchen Ranges
Trying to bypass electrical ignition on oven to
Hi, the gas valves on modern ovens are electrical and cannot be turned on without electricity. Only the cook top burners can be lit manually.
Jan 29, 2010 | Tappan Kitchen Ranges
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Kitchen Ranges Logo
474 people viewed this question
Top Premier Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Premier Kitchen Range Expert? Answer questions, earn points and help others
