Question about HP Compaq nx8220 Notebook
My HP dv6119us just started rebooting itself. Sometimes 10 or more times. The screen remains black. Once in a while Windows XP will start and everything is fine. But, most of the time when I turn it on it simply just keeps rebooting.
  • 561 Answers
Hi
Please can you try the following
1) Switch on Laptop
2) Immediatley press the F8 key continuoulsy until a advanced start up menu is presented
3) Choose safe mode
4) Once in safe mode click Start>Run and type in msconfig
5) click the start up tab and remove all the ticks and then click ok and let the Laptop restart and see if this goes into windows
Regards
Shauqat
Posted on Sep 29, 2010
HP Pavilion dv6119us need drivers for win7
http://www.laptop-software.com/hp-driver/hp-pavilion-dv6119us-windows-7-drivers/
Feb 24, 2015 | HP Computers & Internet
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
Mobile hung on align screen page despite aligning screen several times. mobile was working fine. suddenly system was hung. tried to hard format using call and end button on start up page. ever since the...
Please try this with windows XP
Make sure you:
Turned off any Firewall you have on the PC.
Not running the update in Safe Mode.
Not to perform any other work on your PC.
Make sure the phone is fully charged (important)
Do not update from a PC where you have limited rights. Eg. Internet Cafe, Work etc.
Prefer Laptop as if you have electricity dropped you will have some extra battery and wont harm your phone.
Use only one USB port for you Omnia update, the best one it works for you. Do not try multiple.
Steps used for updating under Windows XP (32 bit).
  1. Make the Install Microsoft ActiveSync 4.5 (once)
  2. Make Install the Samsung Modem Driver XP (once)
  3. http://rapidshare.com/files/179674742/MODEM_DRIVER_FOR_XP.zip
  4. Reboot the PC.
  5. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
    Leave the phone connected for about 10-15 minutes. If it disconnects by itself most probably you have to repeat the procedure from 1st step.
    It is advised to reboot your PC also.
  6. Make sure that have backup all your important stuff (contacts, pictures etc).
  7. Switch OFF the phone by holding the Power button for ~5 seconds.
  8. Run the updater. (Works the same way for Original or Cooked ROMs)
  9. Switch ON the phone again by holding the Power button.
  10. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  11. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  12. Disconnect your phone.
  13. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  14. Enjoy the new firmware.
This is for windows 7 and vista
Things you'll need on Vista:
VMware Workstation (latest will work)
Microsoft Windows XP CD or .ISO image and the serial key
2gb of free disk spaceSafety Tips before starting:
Use the ones that mentioned for Windows XP.
Make sure you turn off the USB on the Windows Mobile Device
Center.How-to disable it. Go to Windows Mobile Device Center:
Mobile Settings -> Connection Settings -> Untick "Allow USB Connections".
After flashing tick it back.Let's start:
  • First install VMware's Workstation. You can get a trial version at http://www.vmware.com/
  • If you have an .ISO image of your Windows XP CD on your hard disk like I do, you won't need the CD, otherwise you'll need it. If you don't have the image, put the CD into your CD/DVD-ROM.
  • Run the workstation.
  • Go to FILE -> NEW -> VIRTUAL MACHINE and choose TYPICAL. On the next tab select the source from where you want to install a virtual Windows XP operating system (CD or image).
  • On the next tab, press next. When the dialog appears, choose YES.
  • Now enter a name for your virtual XP machine and choose a location where you want to save the machine - it's good to have at least 2gb of free space!
  • On the nex tab, I've chosen 2.5gb. I think that's enough, if you wish only to flash your ROM. You can choose to install the machine to a single file or splitted. I've chosen single.
  • On the next tab, click Customize Hardware button and select "USB Controller". Make sure High-Speed USB 2.0 and Auto connect USB devices are checked. Press OK, then press FINISH.
  • Maybe you'll get a warning from VMware but don't bother, just skip it.
  • The Windows installation process should follow. The installation took on my PC for about 25min.
  • When the setup has finished, you can normally run and use Windows XP via WMware.
  • Update your XP machine via Windows Update, reboot and start flashing.
Flashing:
  3. Reboot the PC.
  4. After the first 2 steps try to disconnect your Omnia from USB and connect it back on. Repeat it 1-2 times so the PC can recognize the phone.
  5. Make sure that have backup all your important stuff (contacts, pictures etc).
  6. Switch OFF the phone by holding the Power button for ~5 seconds.
  7. Run the updater. (Works the same way for Original or Cooked ROMs)
  8. Switch ON the phone again by holding the Power button.
  9. Press START and happy flashing. Do not move your phone or the USB wire as it might fail during flashing.
  10. Wait until the updater shows JOB DONE! DO NOT DISCONNECT BEFORE.
  11. Disconnect your phone.
  12. Leave the phone to reboot 2 times, calibrate screen and finish the start-up procedure.
  13. Enjoy the new firmware.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 29, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Laptop won't reboot
are you trying to put win 10 on as it can do this some time, can take upto 10 15 min to load, when the like is flashing its dos, when the screen is black its windows it takes some time for windows to find a driver and load it so the screen comes up. i've had this on a200's before. if you keep rebooting you will need to wipe the hard drive and start again. this also does this on win 7 and 8. win xp it does not do this as its full dos setup .
Jun 30, 2017 | Toshiba Satellite Pro A200-EZ2204X...
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
It's start off good then after Microsoft XP Logo shows it restarts by itself.
your windows xp is serious damage so if you reinstall windows xp again it will work just fine thanks
Oct 27, 2009 | HP Compaq dc5000 PC Desktop
The graphic software failed. no display
When you turn the computer on, do you see the HP logo?
If you don't, keep the computer on and try holding the computer screen under an overhead light at an angle. If you see a faint image of anything on your monitor, then the lights in your screen went bad. A new screen can range $100-$200 on eBay, and can be changed out easily with a small Phillips screw driver.
If you can see the HP logo, it's a driver problem. If this is the case, start the computer in Safe Mode by performing the following steps.
1. Make sure the computer is turned off.
2. Wait for the HP logo disappears and start pressing "F8" repeatedly.
3. A menu will appear. Select "Safe Mode" and let it boot up to the desktop.
4. Once at the desktop, hold down the "Windows Logo" key on the keyboard and press "r". A dialog will pop up.
5. Type "devmgmt.msc" without the quotation marks and click ok.
6. Click the "+" next to "Display adapters".
7. Right-click each entry under "Display adapters" and select "Uninstall" Click OK on the box to confirm. Don't worry, Windows will reinstall it after a reboot.
8. Once all entries are removed from "Display adapters", the category will disappear from Device Manager. Reboot the computer and start it normally.
9. Your screen will probably still be big and blurry. Log into Windows and adjust your resolution to fit your screen. If you select the wrong resolution, and your screen goes black or does not fit, DO NOT PRESS ANYTHING or you will be going back to step 1. The computer will revert back to the old setting after 15 seconds.
10. Once you figure out the right resolution setting, reboot one more time to make sure that the settings took effect, and you can use your computer once again. :)
Oct 25, 2009 | HP Pavilion dv6000z Notebook
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
Acer monitor AL1916W
start up windows in safe mode and see if you still get the problem. did you use the same vga cable???
Aug 26, 2008 | Gateway FPD2275W LCD Monitor
Xp blue and black screen
It seems like you had a software conflict...
Jan 12, 2008 | Microsoft Windows Xp Home Edition English...
HP Compaq nx8220 Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
