Question about Dometic RM2652 Refrigerator
Trailer is plugged in and refrigerator is on auto. Refrigerator works. But when you unplug the trailer the gas side will not light. And when the trailer is plugged in and the refrigerator is set to gas, the gas side works. But when you unplug the trailer, the gas will go out. Or to tell it another way, when the trailer is plugged in, both electric and gas modes work. When the trailer is unplugged, neither mode will work.
  • 24 Answers
In order for your fridge to work when your trailer is not pluged in you need a 12 volt power source, You might have a bad battery or your positive or negative cables are not connected properly. Or a bad connection in the back of the fridge. Check the fuse?
Posted on Sep 29, 2010
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
Apr 21, 2012 | Dometic RM2652 Refrigerator
Is there an easy way to get wiring for a trailer on a 2010 Ford Escape?
Your local auto parts store should have a wiring harness that will clip in to your existing harness. Modern vehicles mostly have a harness coupler under the back of the vehicle you can unplug and plug in the trailer harness without having to cut anything, making the installation very quick and painless. The harness plug may have a plastic lock which you will need to release to separate the two sides of the harness. I recommend putting dielectric grease in both sides of the trailer harness to prevent corrosion from knocking out your trailer lights. The trailer harness kit will have instructions and a diagram to guide you.
Hope this helps and please rate my solution!!
Nov 25, 2010 | Ford Escape Cars & Trucks
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Travel trailer refrigerator will not get cold
Model 2652 Refrigerator The fridge has been perfct till this last trip. the auto light is on and its not getting cold no red lights and i have pluged in as well as unpluged propain is full but i see some yellow dust inside the big cyinder.we may have left the frezzer door open for a couple hour.
Jun 04, 2009 | Dometic RM2652 Refrigerator
2001 Dodge Ram 2500, no running lights on trailer
The truck is protecting itself from the load impose by the trailer.. Chk the plug on the truck for wire gauge size. Turn any electrical loads off on the trailer, any and all. If fuse still blows then the fuse is either underated or the trailer has a dead short. In fact turn trail main power panel of. All lights work you say. So ck the inverter for defect byturning off the inverter on one of the trailers.
May 28, 2009 | 2008 Dodge Ram Pickup 1500
Fridge blows circit breaker when turned on.
The refrigerator is trying to start so start relay and start capacitor and internal fan is our focus.Ok if the doors on refrigerator were closed during this time all the parts will get rust on them so we need to unplug and begin these steps when you are ready, I am here just let me know for sure the model and make match the numbers above your post. Thanks, Sea Breeze
May 14, 2009 | Dometic RM2852 Refrigerator
New Travel trailer......no fridge!
Unit should still be covered on warranty call dometic directly. The tilting could affect some. If you push the auto button in it should run on electric first if no electric present it then goes to gas. Exception to the rule is if the heating element is not working it does not recognize this so it will stay on electric. Unplug the 110v in the compartment on the outside it should change to gas with in a few seconds. If it does heating element is bad.
Aug 18, 2007 | Dometic RGE400 Top Freezer Refrigerator
Dometic RM2652 Refrigerator Logo
245 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
