Question about Canon PIXMA MP830 All-In-One InkJet Printer
Discontinue the use of color ink cartridges permanently
Dear Sir
How do I set the MP830 so that can discontinue the use of color ink cartridges permanently and I don't have to keep pressing the OK button to continue with the print.
I am using the printer as a standalone.
Thank you.
Try holding the stop/reset button down for 10-12 seconds. This should cancel the cartiidges out that you are not using...also click on printer box properties (via control panel) and select print "grayscale"....you can also manually adjust how dark you want the print to be....apply
Posted on Jun 04, 2008
Canon mp830 printing pinkish instead of blue
Hi
You have stick residue in the print head. Just run the print nozzle for 2-3 times to get the correct color.
Also, be sure that all ink cartridges are full because if one of the color is empty, you cannot achieve the correct color when one ink color is missing.
Please let me know if you need more help
Mar 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Have replaced cartridge with one of my refilled cartridges in a canon PIXMA MP830, and am getting an alarm U071,that reads "more than one ink tank of the following color is installed". This is of course...
Printers have a mechanism to detect refilled cartridges. By default it does not accept refilled ones. But there's a work around. Have a set of two (preferably 3) cartridges , refill and cycle them. This way the printer wont be able to detect that you have inserted a refilled cartridge.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
The colour ink is not printing properly on my hp deskjet 5550 printer and I can't find how to do a clean
  1. Click Start , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
PLease note the if you do not take prints regularly there are chances that the ink has dried up in that case refill or replace the cartridge.
Hope this helps. Please rate my response.
Thanks.
HAve a good day.
Nov 26, 2009 | HP DeskJet 5550 InkJet Printer
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
Ink and printer
You'll need to either put it back in or replace it.
You need to have both color and black cartridges in for your printer to work.
Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
Mark
Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP830
pleaz alihn the new cartridde by programing or change the ink ,it may be dry
Sep 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Canon PIXMA MP830 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
