Question about Whirlpool Duet GHW9150P Front Load Washer
Drain The clorox in my new Whirlpool washer will not drain out of the despenser.
  • 21 Answers
You are going to need to find out what is jammed in there. When the cover gets removed, you can see where your clorox bleach solution lines go. Most of the time they drain into the machines' tub. If there is so much as a rock, marble, dirt, a penny jamming this line, it is plugged hard. You will need to find a way to clear the debris the best you can. becareful, and make sure your washer is unplugged when you do any service work.
Posted on May 26, 2008
Whirlpool refrig. model EET222MKDRO. large puddles of water under crispers every other day. cannot find defrost drain. is this a costly repair or is refrig. shot. thank you.
That drain is below the evaporator and under the defrost heater. To get to it you have to remove the service panel to the freezer section. Use clorox and hot water or a wet dry shop vac to clear the drain.
Aug 28, 2011 | Whirlpool Refrigerators
Towels have bad order
run it through a cycle to clean it with clorox bleach, make sure there are no clothes in it ;)... also your washer has a clean washer cycle.
Jul 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How much chlorox go in the washer to rinse it.
only use 1 cup full, the washer is designed to allow enough water to rinse out the clorox
Jun 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Fabric softeneer despenser has water in it. We have not used the despenser. Have a whirlpool cabrio top loader
Had one where the softener dispenser had all kinds of dried up crud from the softener which caused the water to collect there instead of drain down. It actually looked like wax, after cleaning it out the water problem went away.
Apr 20, 2011 | Whirlpool GSC9455 Top Load Washer
Whirlpool LHW0050P Washer- Can I use Clorox bleach for my whites? Where do I put it?
It is not recomended to use bleach in these machines...that's why there is no place to put it in the dispenser...
Nov 14, 2010 | Whirlpool LHW0050PQ Front Load Washer
Sometimes before washinging cycle complete I get an F9 code
Is it still spining and what else is it doing,Have you sanitized or cleaned washer use 1/4cup of clorox bleach (he) run through wash cycle no clothes. see what this does
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dont' know where to add bleach alternative
yes clorox 2 or "dry type" bleach should be put in with the detergent. only liquid bleach will go into the bleach dispenser.
also be sure to use soap that is "HE" type or you will get too many suds and a washer that will smell from not rinsing out.
Mar 29, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
No water
two things may have happened, first the o-ring washer on the pipe tap may have shrunk and restricting the flow of water, second the filter for the machine may be plugged up and need changing. good luck and if yoiu still need assistance feell free to ask againd
Jan 19, 2009 | Whirlpool ED2FHSS Side by Side...
My new Front Loading washing machine has a terrible mildew problem!!!! I have used clorox bleach, lisol, clorox spray cleaner and the problem goes away for one load. If a new load sits for more than 30...
your drain where the hose drain hooks to your house isnt draining fast enough ,there must be lint in the pipe ,when your washing machine pumps out the water the pump shuts off ,but the drain hose is syphoning the water that the drain pipe has in the pipe back into the machine
Jul 08, 2008 | Whirlpool Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
