Question about Sun StorEdge L8 Autoloader Ultrium Tape Drive
No power on tape device. Re-plugged power cord and cycled the power switch.
    Novelist:
  • 112 Answers
Check for a replaceable fuse. Look on the back of the unit where the power cord goes in to the case. Typically in close proximity to the cord there is a fuse in a screw-in type receptacles, usually black in color. PLEASE UNPLUG THE UNIT TO REMOVE IT.
Posted on Sep 29, 2010
Where can I get a replacement plug that this cord will plug in to for my led lighted qillow tree
M12S 2 Pin Waterproof LCDs Led Power Supply Connector Replacement Black
44cm Length 2 Pin Waterproof Extension Connector Cable for LED Strips
get a 12 volt 5 watt power supply and cut the wires and connect red to the red or white stripe and black to the other,plug in to make sure it works if it doesnt,switch wires,then tape each connection with black tape
May 25, 2015 | Computers & Internet
Power Switch won't turn device off...
The transport is trying to finish a cycle. The power off is not he only problem with the unit due to this.
Jun 28, 2014 | Denon DRW840 Single Dual Cassette Deck
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
Tape stuck in drive
The best way that I have solved this is by using the move commands from the drive, and move it from drive to any free tape slot. Also if that does not work, put a few tapes in the drive and perform the random moves test in diagnostics, that will fool the drive to move the tape.
Jan 29, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Kirby G6 Power Switch Test ?
You can look at the wiring diagram and try to figure out how to use a circuit tester to test the switch but I would just suggest just swapping it for a good one (always good to have one good switch for testing) and see if it solves the problem.
Good Luck
Rocky
Oct 27, 2008 | Kirby G6 Bagged Upright Vacuum
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Tape deck won't eject tape
The tape might be wrapped around the head or the capstan. The mechanism is delicate so you risk more damage by trying yourself - check with some of the repair shops on the Fixya home page for prices to remove the tape.
Dec 17, 2006 | Canon ZR10 Mini DV Digital Camcorder
Sun StorEdge L8 Autoloader Ultrium Tape Drive Logo
165 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
k24674
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
