When i turn on i hear a sound then 51.2k error
    Champion:
  • 202 Answers
IT IS A BLACK LAZSER SCANNER ERROR IN CLJ 4600 CLEAN & REFIX THEM PROBLEM RESOLVED IF PERSISTS THEN REPLACE THE LASER SCANNER
Posted on Sep 29, 2010
I have a samsung dishwasher dms300trs. it is showing an error f3 .I wanted to know what does this error mean and how do i fix it.
un plug from mains and turn off water supply and remove the water pipe. leave water off the unit. and plug unit back on at mains and turn on. using lowest setting turn on using this you should hear it moving about inside and a pump sound. if you dont hear a pump sound turn off and check that the drain pipe is not blocked. it sounds dirty but if you can blow down the drain pipe with the unit off it should be easy to blow down if not then its blocked inside. for that you will need to clean it out. here is a link to the pdf for the dish washer SAMSUNG DMS300TR User Manual hope this helps.
Apr 04, 2016 | Samsung Dishwashers
Printer either has a paper jam or error out of paper when the tray is full
Then have tech come out and look at it sound like a sensor is bad and ore the rollers are dirty that sound you hear is a clutch turning do not continue to do that
Apr 22, 2015 | Office Equipment & Supplies
When i turn onToshiba Satellite M100-JG2, get black screen,and hear 2 bee sounds,computer won't start.
Two beeps a generally a memory parity error.
Use a test utility like memtest86 to check it. Youll need another computer with a CDRW to create a test disk from an ISO.
Then boot the computer with the cd in and it should run from CD.
Memtest86 Advanced Memory Diagnostic Tool
Jul 02, 2014 | Toshiba Satellite M100 Notebook
When i call someone i can hear them but they cant hear me... i want i best solution,,, and my computer says "no sounds card found."
this indicated your sound device was error or sound driver error
try to reinstall sound driver first, if stll error like that place new sound card
Mar 31, 2011 | Computers & Internet
Have sound no picture lamp does not appear to be bad when looking at it yellow light blinks the shuts off tv then tries to start and can hear sound but no picture it will keep doing this till i turn the tv...
listen for the colorwheel noise
you'll recall hearing it "wind up" as the tv came on
many of these will go bad and then it will never fire the lamp because the colorwheel doesn't get up to speed
if you don't hear it, suspect the wheel, its hard to get since toshiba never had it as a seperate part
if you do hear it, its probably a bad lamp driver, but unlikely
let the tv go and go, it will try like 7 or 8 times and then eventually spit out an error. your user manual has the error codes, it will tell you if its the colorwheel i belive.
let me know if you need further assistance
Jun 06, 2010 | Toshiba 56HM195 56" Projection HDTV
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Sound plays on my system but i dont hear it at all.my windows
Let's start by checking
  1. Your speakers are plugged into the green connector on the computer
  2. Speakers have power, are turned on, and volume is up
  3. Check your "speaker" icon on your tray (lower right hand corner of desktop) - to make sure volume is up and not muted.
Sep 15, 2009 | Dell OptiPlex GX240 PC Desktop
Need help
Error messages seen at power-on if not caused by the memory card are generally related to the lens assembly either being jammed or malfunctioning. We do not see many Casio cameras here in my shop but I can say that statement applies to these kind of cameras in general. Hold the camera close to your ear when you power it on. Do you hear a series of different sounds, or do you hear chattering or repeating sounds? Perhaps no sounds at all? David Millier Advance Camera Repair
Feb 20, 2007 | Casio Exilim EX-S3 Digital Camera
43 people viewed this question
k24674
jasbo
jasbo
