Question about Sony Ericsson XPERIA X10 Cell Phone
Its seems that the screen keeps freezing when on the internet and when writing a text message, the back button (the button on the right at the bottom) doesnt seem to work and the only way to get out out of the screen i to switch the whole phone off and tart it up again. i thought it wa a fault in that actual phone, and i spoke to my network provider and they sent another one out but the problems are still persisting... is it a fault with the phone or something im doing wrong?
  • 4,102 Answers
Hi, the problem you are having is with the phones firmware you will need to take this phone into a phone shop and have the phone flashed and the firmware re-installed, the problem with this is you can only have it done at a phone shop as they need to install all the software back on the phone and the other problem is that this will wipe the phone so you will lose anything on it.
you can back it up if you have the leads to your computer and the correct pc suite for your make of phone if you dont have this just ask the phone shop to back it up for you.
their is no other way of doing this as you cant get the firmware and re-install it yourself the phone shop will charge you for doing this but it will be cheaper if you go to one of those independant shops instead of one of thos bigger branded ones.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
f1
Posted on Sep 29, 2010
When I try to delete text messages it freezes the
open the back of the phone. take out the battery. You will see six hole for screws. The one to the right beside the battery should not be a screw. press it 2 or 3 times with something small. Reinsert battery it should show a reboot screen. I just tried it and all my data is still there. let me know if this works. seems to be a problem cropping up with several others as well.
May 23, 2010 | HTC Hero Smartphone
My phone keeps freezing and restarting
it will end up costing you about 15 dollars but take it to a repair shop for the provider you use and they should be able to save all your info and flash a new version of the software onto your phone but it won't be free, that's the only way to fix that without buying a new phone.
Dec 28, 2008 | Verizon Communications enV2 Cellular Phone
T-Mobile Wing Freezes & Restarts while texting
you can try to restart the phone. The only problem with that is that everything you have saved on ur phone gets deleted unless its on a memory card. What you have to do is turn off your phone then wait a couple of seconds then hold the power button along with the to line buttons by the green phone and the end call button. After you hold them down you wiil see a screen that will have some writing when that shows up you press the green phone button. After that it will restart but its going to take a while for it to restart. then when its done deleting everything its going to ask you to tap the screen the its going to ask you to do the align screen. you can skip the rest after you skip it the pocket pc page will come up and it will show you its installing everything when its done it will turn off and start up again. and there you go like new. if that doesnt help the you should go get it checked out..
Dec 25, 2008 | T-Mobile Wing™ Smartphone
Deleting all text messages
hello
have you tried
From your text message screen click MENU then FOLDERS. Highlight the folder you want and click MENU then DELETE ALL to remove even ones saved to the SIM or CLEAR MESSAGES to delete just ones stored on the phone.
also a manual can be download for futher refference if needed .
Pantech duo™
riz.
Apr 30, 2008 | Pantech Duo Smartphone
As soon as i try to write a text message my phone freezes
when i push the first button to write a text my phone freezes and i have to take the battery out what do i do
Apr 26, 2008 | Motorola Cell Phones
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Phone freezes while texting
delete your messages and let it cool down 4 a day it happend to mine and its fine
Mar 27, 2008 | Samsung SGH-U600
My phone freezes when trying to create a text message
try deleting some text messages, especially your outbox and unused files on your phone.
Feb 10, 2008 | Motorola Mobility RAZR V3
Touch Screen 'Back' button on my K850i affected by every other button.
problem solved. i had the same problem but i fixed it somehow. one day i just took a iron thick pin and pressed the space between number 5 and left-down button(not in the gap). and then i pressed between left-down key. Instantly it started working fine. i dont know whether it was my luck or i just accidently found a solution.756425f.jpg
Jan 23, 2008 | Sony Ericsson W850i Cellular Phone
Screen trouble
try *2767*3855# this should help, if it does not then take it to a repair center and have them reflash the firmware on the phone.
Nov 18, 2007 | Samsung D840 Cellular Phone
Sony Ericsson XPERIA X10 Cell Phone Logo
290 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
