Question about Mitsubishi LT-46148 46 in. HDTV LCD TV
Vertical lines This is the second panel that has had this problem
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
I have vertical lines on the entire right side of the screen on my Olevia 242-S11. I've replaced the t-conn board three times, the first and third gave me a black screen, the second gave me less...
most of the stuff from jimmy's its second hand ( not good working or working maybe) first and the last i suppose you got a problem with the power supply on the T con on the second i suppose you have a problem with the big chip in the middle the scalier :D
Jun 02, 2011 | Syntax Olevia 527-S11 Television
I have a LT-46244 and there are two vertical black
No format burn-in if thats what you mean, tv needs to serviced. good luck Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Hitachi 42EDT41A Turn On with white and yellow vertical lines
you have to replace the vertical sweep IC and check the voltage across its VCC. If you cant understand tech words, better visit the service center.
Jul 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Vertical lines in my LTV 19bg tv different colors yellow, blue, pink,white, black, no image only vertical lines with sound
need to reset the remote. Point remote at TV and hold down enter button for 10 seconds.
May 13, 2008 | Astar LTV-19BG TV
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Mitsubishi LT-46148 46 in. HDTV LCD TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
