Question about Grilling
Jenn-air grill I just bought this grill----Jenn_Air Model No-720-0336 and the rotisserie burner keeps going out after it gets hot.
  • kkinderati Jun 24, 2008
    I have the same problem . Back Burner runs for about 4 minutes then almost sounds like it blows up and then the regulator for it shuts down.
  • Anonymous Aug 10, 2008
    I have the same problem. This is not the regular burners, but the ceramic burner on the back of the grill.
    How can I keep it ignited?
Sounds like you need to call Nexgrill to get a replacment as this is under warrrenty. Sounds like it is cracked.
Posted on Sep 07, 2008
Cleaning burners"
Posted on Jun 09, 2008
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Jenn- Air rotisserie burner wont lite. Doesn't
Try removing the cover on the back of the grill hood and finding the orifice for the rear burner. Check to see if the orifice is plugged.
Jul 31, 2011 | Jenn-Air Grilling
Do Jenn-Air have recommended suppliers? I have a Jenn-Air Gas Grill Model 720-0163 and need burners.
Appliance Factory Parts is a good place to start. They carry parts for just about all makes and model grills. If you can't find what you need under Jenn Air, try looking under NEX Grill. Actually, they are the manufacturer of the Jenn Air Gas Grill.
Hope this helps you. Please let me know. Happy Grilling.
Jun 26, 2011 | Grilling
Hi There, I have a Jenn Air Gas Grill that I purchased at Lowes with a lifetime warranty. My Model# is 721-0336. We need 3 new burners and two small spacers that go between the burners.
Hi, you have to contact Clagrill on 501-821-4050 to request for your parts. I think they have a free shipping policy within the US.....
Aug 29, 2010 | Jenn-Air Grilling
Trying to install the rotissere on our Jenn-Air outdoor grill. Instructions lost and the installation seems impossible!! Help!
I have instructions for model# 720-0093 Jenn-Air rotisserie, pretty simple, 4 bolts total. Must admit, I had to go back to Lowes for help since I was trying to install brackets the wrong way. Will be glad to email these to you, let me know @
Aug 16, 2010 | Jenn-Air Grilling
I have a Jenn-Air gas grill model #720-0061-LP it has 3 brass burners and a rotisserie burner on the back wall. the flame from the middle burner is shooting back into the knob causing issues with the...
I have had the same problem before with same exact grill. The burners get clogged and the gas pressure backs up. I have had this actually split a gas valve and the plastic electronic igniters do not have a chance withe the head. Call nexgrill and get all new burners under warranty. This will solve the problem for a while. The latest burners that I received in Aug 2010 are 1/2 inch shorter and may solve this problem. You may want to buy new gas valves since the excess heat in this area may have damaged the valve. Since 2004, I am on my 5th set of burners, 2nd set of gas valves and 3rd electronic ignitor. May just recycle grill and get a Weber or go with charcoal.
May 09, 2010 | Jenn-Air JLG7130A
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
Sep 16, 2008 | Grilling
Jenn Air 720-0061-LP Gas Grill Rotisserie Problem
Hi all ,
I just bought a jenn air 720-0336 gas grill from bj's . the rear rotisserie burner would stop working after a few minutes .
hear is the deal , the rear inferred burner gets to HOT . they did not put any insulation between the ceramic blocks and the metal bezel.My fix was to remove the unit , drill out the 8 rivets holding the bezel on , carfully remove the bezel and install a fire proof gasket , i was abile to find the proper stuff at my local coal / wood stove comes in a white sheet about 1/8 inch thick .
use steel rivets to reassemble . good luck . this took a week of trial and error to figure out .
Aug 02, 2008 | Grilling
Rotisserie won't stay lit
With our Kenmore, you need to increase the gas flow another 1/4 turn once it's lit.
May 25, 2008 | Grilling
Grilling Logo
415 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
