Question about Whirlpool RBS275PD Electric Single Oven
Fan staying on - Whirlpool RBS275PD Electric Single Oven
    Genius:
  • 1,416 Answers
Hello
Yes, this is normal. The fan stays on for a period of time to help cool the oven.
But if it stay too long then it means that there has been a problem on the wiring programming connected to the fan
thank you and thanks for using fixya.
Posted on Sep 29, 2010
Cooling fan on my neff oven stays on when I set it in auto is this normal
Are you sure you mean 'C ooling Fan' and not 'Circulating Fan' which should come on if the temperature selection is higher that the current temperature.
Oct 10, 2016 | Neff Ovens
The cooling fan does not switch off after oven has cooled
function button or switch could be faulty
maybe that brand of fan forced oven
uses a thermostatic switch to that fan
Jul 03, 2016 | Ovens
Oven fan stays on
some ovens have a cooling fan that is controlled by a temp sensor, this will keep the fan running until the area where the sensor is cools. probably normal if it turns off after a while.
Jan 31, 2012 | Ovens
Have a stoves 720 es main oven fan does not stay on to cool oven after switch off> also the oven will not trun back on when it is still hot or warm ? will
First things first. There are two fans. One in the bottom oven and one to provide background cooling. The background cooling fan turns on when anything is turned on. (Fan oven/top oven/grill). Just operate the top oven for a moment and this should cause the cooling fan to operate. There is a printed circuit board that controls the cooling fan and for how long the fan should stay on once everything has been turned off. (About 7 mins). If this fan is not running then the fan/motor could be faulty, or the circuit board or the resistor on the fan terminal block. The reason the oven will not turn back on is that the residual heat in the oven unit as a whole against the fan oven, is probably too high which causes the overheat device to operate.
You will have to take the oven out of the kitchen carcass, take the top and rear panels off and get an electrician to test and found out which item is not working/failed. Try espares for parts.
Jan 24, 2011 | Stoves 720EF Electric Double Oven
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Vent fan stays on
The fan was on because the griddle element was on. 1/2 of the element was on so 110 volts was on at all times. If I had not been close to the oven and heard the fan I might never have found this problem. I replaced the infinite switch and that solved the problem. I found the model # inside the drip jar door. Problem solved.
Mar 18, 2009 | Jenn-Air JGW8130A Electric Single Oven
My neff oven b1664 rear fan element stays on after switched off
I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
Dec 11, 2008 | Ovens
Creda colonial oven
If it is the external fan that is staying on as opposed to the oven fan then it is probably a faulty thermostat that controls the cooling fan.
Dec 04, 2008 | Zanussi ZHQ575 Electric Double Oven
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Whirlpool RBS275PD Electric Single Oven Logo
275 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
