Question about Fuji FinePix A900 Digital Camera
Need Help My camera will not allow me to take pictures, it shows an error message that says " frame no. full ". I do not have my hand book availavble as I am on vacation. Please Help.
  • tartansponge Aug 24, 2008
    Same problem and used exersize below to remedy, however, one important point before doing this, save existing pictures and empty/delete the card, as renew does not return to 0001, it returns to the next number in the sequence remaining on the camera.
    For example, I left my last photos on and deleted only one (9999) therefore the last photo was numbered 9998, meaning once renew selected it allowed me to take a new 9999 before showing Frame No. Full again !!!
    To sum up, delete all photos on camera then click on Renew and you'll be laughing.
    Take the time to read the explanation in section 4, only took a minute.
    http://www.fuji.fi/documents/12/f10.pdf
    Frame number has reached max.
    Go to menu
    Go to set up
    Go to the second tab
    Go to frame number
    Set to renew!
    And my camera started working again
I think I found it. Look here
Go to menu
Go to set up
Go to frame number
Set to renew!
Posted on May 28, 2008
I have the exact same problem, and I have the handbook and I cannot find an answer either!
Motorola mf 700 digital photo frame hand book
When loading pictures, the last picture selected displays first in slide show rather than at the end. Therefore, the sequence of the picture is out of date. Why does this happen?
Mar 17, 2012 | Cameras
I have a J10 fujifilm camera and it currently has an error message: FRAME NO. FULL! I have the following picture card: Fujifilm xD xD-Picture Card M1GB Any advice would be appreciated.
Try formatting the memory card. If that doesn't work, try a different memory card. If that doesn't help, sadly, it's probably time to return the camera if it's still under warranty.
Jul 13, 2011 | Fuji FinePix J10 Digital Camera
I just bought a digital photo frame for my husband for christmas and i get so many pictures downloaded...then it just stops and says insufficient memory card.....i thought there was something wrong with...
I'm pretty sure this means that you have filled up the internal memory on the picture frame.
I just bought my sister a photoframe for Christmas (made by Phillips) and we got the same message. Not the most precise wording on the error message, but we tried deleting a few photos and the error went away. Then I checked the internal memory of the frame, and it is only 128M, which is not alot of photos.
I think the solution will be to buy a USB memory stick to leave in the frame. For about $10 you can get a 4G USB memory stick, which is about 32 times the space of the internal memory, at least if you have a similar model as we do.
See here: http://www.amazon.com/USB-Flash-Drives-Storage-Add-Ons/b?ie=UTF8&node=3151491
Dec 23, 2010 | Philips Cameras
!Frame No. Full and cannot take pictures
Well i was just having the same problem and decided to search for an answer. It looks like you might want to reset your camera. Go to menu, set up then click on three and you should find "reset" click that and in no time you will be able to take pictures again!
Mar 21, 2009 | Cameras
Fuji finepix a900 Frame number full error
Hi!
In case you haven't sorted this out yet.
To fix this go into Menu ---> Setup. From there there's a Frame Number setting. It is normally set to: Continuous. The other option is: Renew which evidently simply resets the picture count. After selecting Renew the error message disappears and the camera works perfectly again.
Great little camera!
M
Mar 17, 2009 | Fuji FinePix J10 Digital Camera
SAF error message & blurry pictures
maybe you need a new memory card if your card is full sometimes it can cause a camera not to work or shut down because of an overload of files.  If you memory card is not full most likely your camera has a defect to it. I suggest you take to a person who specializes in fixing cameras by your company. For the burry picture thing, there are different settings on a camera and I'm pretty sure that there is one to sharpen the picture images.
Feb 13, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Built in memory full...?
I have new camera ,After shooting 12 photos it's show Built in memoru full and cannot shoot anymore
Jan 23, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Camera says Frame no full cant take anymore pictures Help!
Copy your card to hard drive, reformat your memory card, and see what the numbers of pictures it gives you.
If you lower the resolution of the camera, the more pictures you can take.
Jun 16, 2008 | Fuji FinePix F480 Digital Camera
Fuji FinePix A900 Digital Camera Logo
89 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
