Question about Yard Machines Garden
My Yard machine will not turn over at all. the batterie is fully charged, theres no corrosion on the terminals. So what else could be causing this?
    Scholar:
  • 150 Answers
Check the connections on the starter solenoid. Assuming starter is good, thats the prob. Check connections on ignition switch
Posted on Sep 29, 2010
Getting ready for summer my lawn mower didn't start. I charged the battery and have power but nothing happens when I turn the key to start
take a screwdriver and firmly touch the positive to neg. on starter...if that turns the engine over...then its the selonoid or a bad connection......possibly could be the ground on the batt.
Mar 31, 2015 | Garden
Car wont start but batterys good
A fully charged battery does not mean that its amperage output is adequate, have it tested at an auto parts store. While your problem could be battery, wiring, key switch, solenoid, starter or maybe really cold outside, best to start with simplest first, clean the battery terminals and cable connectors with a terminal brush tool and install anti-corrosion impregnated felt rings on each terminal. With the battery terminals disconnected, also unbolt and clean the solenoid and starter terminals too and re-tighten. Then find the "ground" connections from the negative battery cable to the metal chassis and from the engine to the chassis, unbolt, clean, sand clean each if necessary and reinstall. If when using a voltmeter there is any reading between the engine block and the negative terminal of the battery, installing an extra ground cable directly between the engine block and the negative battery terminal connector. When reinstalling battery terminals, install positive terminal first, place socket slightly larger than battery terminal on top of it and lightly tap to fully seat the cable connector on the battery terminal before tightening. Tighten snug enough that cable connector does not move on the battery terminal, do not over tighten. Beware of battery acid and accumulated corrosion, wear eye protection and protective gloves too and be aware that battery acid eats holes in clothing and cloth gloves. If problem persists, a DC voltmeter most useful to determine if when key turned to start, there is voltage applied to the solenoid. If yes, then to check if solenoid operates upon key turn to "start" applying voltage through solenoid to starter. If yes, and if battery amperage output tested "ok" then starter may need to be replaced.
Mar 19, 2014 | 2003 Honda CR-V
Camera won't turn on
If none of the suggested causes helps resolve the issue, then I suggest you bring it in for repair.
Please check the following things when the camera does not turn on.
Possible causes and how to handle them
1. The camera is not on
Turn on the camera. (Operation procedure varies between camera models. Please refer to the camera user guide supplied with your camera.)
2. The rechargeable battery is not fully charged.
Make sure the rechargeable battery is fully charged. If the battery has not been used for an extended period of time, or if it is being used for the first time, it may not be fully charged. In cases like this, fully charge the battery and then discharge it completely in the camera several times to bring the battery back to its normal performance.
The rechargeable battery's capacity diminishes the longer the battery is used. When the battery consumption becomes quicker, the battery life may be at its end. Replace the battery with a new one.
3. The battery terminals are dirty.
When camera does not operate with a brand-new alkaline battery (for cameras that use AA-size batteries) or with a fully charged rechargeable battery, the terminals may be dirty.
Polish the terminals with a dry cloth and make sure the terminals are clean. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and power may not be fully supplied to the camera.
Also, polish the battery charger terminals with a dry cloth before charging the battery. If the terminals are covered with oil from your skin or similar matter, this may cause poor contact and the battery may not be fully charged.
4. The batteries are not installed correctly (for cameras that use AA-size batteries)
For cameras that use AA-size batteries, multiple batteries are used in one camera. Make sure the direction of each battery matches the direction indicated on the camera. If any of the batteries are improperly inserted, the camera will not operate.
5. The battery cover or CF card (SD card) slot cover is not securely closed
Most cameras have a lock mechanism on the battery cover. The camera will not turn on if the battery cover is not locked or securely closed, or if the CF card (SD card) slot cover is not securely closed. Make sure these covers are securely closed.
If your camera does not operate after checking each of these things, or if there is any visible damage on your camera that could be the cause, please contact the nearest Service Center.
May 03, 2012 | Kodak EasyShare C330 Digital Camera
Car wont crank at all and the battery is fully charged up. what will cause it not to crank up?
Corrosion on battery terminals Loose battery wires connected to starter Dead starter
Jul 13, 2011 | 1995 Pontiac Grand Prix
Five minutes ago our 1988 Dodge Grand Caravan was running. I replaced a brake light bulb and started it to test. Now it is dead. Completely. No current getting from the battery to any electrical...
Take a volt meter and read the battery terminals to insure there is power. You should have 12 volts dc or a little over. This may be caused by a direct short in the battery cables. Also tight aint always right. It doesn't matter how tight you have a connection if there is something (ie corrosion) interfering with the connection. To check this clean the terminals with a battery brush or a rough brush or file, then reconnect the terminals.
P.S. Coca Cola will also eat the corrosion off of anything.
Apr 17, 2011 | 2000 Dodge Caravan
BATTERY IS FULLY CHARGED. TRY TO TURN IT OVER BUT, GOT A MULTIPLE CLICKING SOUND.
make sure terminals are tight and not corroded if ok then make sure there aint green corrosion in the battery cables however before you do that have battery tested ive seen alot of people have bad battery that was fully charged cold cranking amps it is cold out.
Feb 04, 2011 | 1998 Ford Taurus
Where is the generator on a yard machine lawn
no generator or alternator power generated by magnetic pulse[magneto]on the top of motor the fly wheel has magnetic inserts that pass thru a armature/coil causing a pulse sometimes the flywheel gets surface rust but that would also affect spark --check connections and test battery battery may not be holding charge or loose or corrosion in wiring can cause battery problem
Jun 10, 2010 | Yard Machines 155 Torque Briggs Stratton...
Truck just makes a clicking sound when turning the key. battery is fully charged
ACTUALLY I HAVE A 2004 FORD EXPEDITION WITH THE SAME PROBLEM AND ITS YOUR STARTER GO OUT AND HIT IT WITH A HAMMER A COUPLE TIMES IT WILL START THEN DRIVE IT TO THE SHOP CAUSE IT NEED TO BE REPLACED THERE IS A DEAD SPOT IN THE STARTER
Dec 10, 2009 | 2004 Ford Expedition
Camera
Courtesy: http://photography-on-the.net/forum/showthread.php?t=151603
Jul 20, 2008 | Olympus FE-210 Digital Camera
Kodak easyshare z730
May 19, 2008 | Cameras
Garden Logo
215 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
