Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Kp2671 quits spinning under heavy load and making a grinding sound. What part might it be?
  • KitchenAid Master
  • 17,130 Answers
This is usually assocciated with the wearing of the Bushes in the shaft as there is play.This norrmally develops on a period of time due to water and dirt accumulation.
You will need to remove the drive and put in new bushes to suit for a tight setting.
Posted on Oct 01, 2010
KP2671 wont turn on
there could be a thermal over load switch that you may have to press
if there isn't,take it in to an appliance repair shop for a look and quote
Jun 26, 2016 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid 525 stopped working while mixing cookie dough
Let it completely cool and then start again. It overheated because your speed was set too low for the heaviness of the dough. I have burned up three kitchenaid stand mixers so far making bread. go up one setting at least; if it is straining, go up another.
Dec 15, 2012 | KitchenAid KP2671 Professional 6 Series...
The motor is making a grinding noise. The mixer still works, it just sounds weird.
I have fixed many mixers with the same problem. The only part that consistently wears out
is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out
and becoming chipped. The grinding noises you hear are made by the Worm Gear and the
Follower. As time goes on, the metal filings from the damaged follower will eventually destroy the Follower and the Planetary will stop rotating.
Sooner or later that gear need to be replaced. Also remember to use new Grease after
a new gear replacement (metal filings from the old gear will damage your new gear)
Apr 02, 2011 | KitchenAid KP2671 Professional 6 Series...
My mixer is making a grinding sound. I had it serviced a few years ago, because the gears sounded like they were slipping when making bread doughs. The service center said it only needed an oil change....
Its worth fixing but having someone who specializes in your product is the key, these machines are wonderful products and engineered great. I would say if your mechanically inclined jump on inside the machine and see whats going on, but if your NOT send unit to us USPS it's not that expensive plus you would only have to pay oneway, we will take care of the shipping from our side,,estimated cost $29.00-$49.00
Nov 13, 2009 | KitchenAid K5SS Heavy Duty Commercial...
My Kitchen Aid KSM150PS Artisan red mixer trembles alot and makes a grinding sound when I use it. I've exchanged it once already and have the same problem again.
Kitchenaid mixer are supposed to make a slight grinding sound while operating under load. This is simply the gears meshing together while the motor is turning them, but if the sounds gets worse or is already a metal grind type sound this could indicate a broken worm gear inside the unit, and shouldn't be run any longer. However if your mixer isnt on SOLID ground this could cause the tremble as well.Hope this helps
Thanks
Oct 31, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Under a heavy load, the mixer began clunking once per revolution
Disassembly and inspection is the only way to verify what it is. It sounds like you are correct. I have bought parts very reasonably on line and repaired our K/A mixer. The better sites ( I think I used appliancerepair.com) have exploded diagrams. If you are tearing into yours, these are invaluable, and when you get to the broken part, you'll have a name for it.
Best regards, --W/D--
Aug 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Mixer turns on revs to a high speed and then quits
I replaced the control board on mine, and that seemed to resolve the issue
Nov 24, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KP2671 - Spaghetti cutters stopped turning. Makes loud noise.
this is common for any device that has a motor,either the gears are grinding or the motors contact brushes need replacing, it will have to be looked at to determine the exact cause
Oct 13, 2008 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid pro 5 --dreadful noise; filings
the company jumped right in and helped me out. impressive.
Sep 08, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
70 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
