Question about Line 6 Spider Iii 30
My son has a Line 6 Spider III amp. The sound disappeared. I was told the problem is the power transformer had no power any longer. I need a 1X-5730-04H0 to replace the bad one. Where do I order from? How much does it cost? Help.
  • Line 6 Master
  • 5,603 Answers
Transformer failures are VERY UNCOMMON. I would verify the problem before trying to find one.
Most failures are with circuit board cracks and electrolytic capacitors.
Find a very competent electronic technician to check this out.
The RARE failures that occur in transformers are often poor soldering right near the terminals or lead wires. These can often be repaired without replacing.
Posted on Sep 29, 2010
Line 6 spider ii. As soon as I turn on the power I get a huming sound. can not adjust anything. The only sound is the hum. Could it be a transformer problem! much appreciated
Not a transformer problem... this is likely filter capacitors, rectifiers, and PROBABLY a bad amp chip. Service this before it wrecks the speaker.
Jul 18, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Don't need a repair. I need a manual. know where I
Line 6 has the manuals on their site.
The Spider III 15 is in two parts: part 1 and part 2
The first is the manual, the second is the sample settings.
Both are PDF files.
Jan 20, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
Hi My line 6 spider 111 30 has a problem The amp will switch on but there are no light showing and no sound, there is power to the amp as it will hum slightly when switched on
The hum MIGHT be directely from teh power transformer vibrating the chassis RATHER than via the speaker. This is an important detail to investigate.
Jan 14, 2010 | Line 6 Spider Iii 30
On any channel I've begun to get a intermittant
If this has a digital effects processor read on.., I had a SIMILAR problem on a Behringer GX110.
The electrolytic filter cap for the 5 volts of the DSP effects had gone bad. The 5 volts was dipping when the DSP reset and it would repeatedly reset causing a clicking at about once a second. 50 cent part fixed it. The part is a little undersized electrically so is more prone to failure in the unit I have.
That particular one had the DSP as a seperate board with its own 5 volt supply from the main transformer.
Dec 18, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Black boxes on the lcd screen of the spider 6 III amp
unplug it and open it up. there are ribbon tape connections in there that arent very secure. maybe one came loose...
Mar 28, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Make sure both the master volume and channel volume is up. If that does not do it, take it to the nearest Line 6 repair center.
http://line6.com/support/serviceCenters/
Mar 28, 2009 | Line 6 Spider Iii 30
Line 6 Spider Iii 30 Logo
237 people viewed this question
Top Line 6 Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Larry Stiles
Larry Stiles
Are you a Line 6 Music Expert? Answer questions, earn points and help others
