Question about B&W DM603 S2 Speaker
Please who can I contact to source replacement tweeter part hf/2210111 for my bw 603's
Don't understand how to connect my speakers
the 4 inputs are for biamping, (using separate amplifiers for low and high frequencies). just leave the pins in place and connect the amplifier to one red(+) and one black(-) connector on the speaker. It has an internal crossover to protect the tweeter.
Nov 20, 2013 | Audio Players & Recorders
I just bought a pair of Tannoy Mercury V4 with a broken tweeter. Where do I find a new one?
check to see if you can find it on parts-express.com that's where I get all my speaker stuff
May 28, 2013 | Tannoy Audio Players & Recorders
I installed a Q05-19700-00476 input PCBA for B215A componant. when I connect to the tweeter it blows it please help.
Certainly your hf driver is getting amp rail voltage, this is why tweeter blows, disconnect tweeter and with the unit powered on check the tweeter leads with a voltmeter and let me know the readings, but surely will be dc voltage...
Jan 02, 2013 | Behringer Eurolive B212A Speaker
Tweeter wires burns up tweeter when connect to it
I'm Serge.I'm a professionnel electro-tecnicien with my diploma. Anyone who have a question,i'll answer,FREE . i have my reasons for doing this. You are getting cc or dc voltage in your tweeter and it blows.Your tweetter amps is defect.Make it fix and be carefull.That type of circuit is very very sensible and technic and double layer printed circuit.By the way check the bass amp also.Thank's Serge.
Dec 20, 2012 | Behringer Eurolive B212A Speaker
How do i tell if my problem if the high freq diaphram or the cross over
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Apr 02, 2011 | JBL PRX515 Speaker
Mission 753 spares / tweeters hi can you help me please ? my tweeters from my mission 753 floorstanding speakers have blown.. been in contact with mission, and have been told that they no longer have...
Hi Ricky...saw your post re the 753 Mission tweeters. Your post goes back some months ago but I wondered if you got fixed up with replacement ones or a workaround ??
Regards
Wayne
urban494@hotmail.com
Jan 29, 2010 | Audio Players & Recorders
Same here man...
These are Bi-Amped, that is have seperate amplifiers internal for the LF and HF.
First have to find if the amp or the actual speaker driver is bad.
Aug 19, 2009 | Mackie MR8 150W 8 Active Two-Way Studio...
Tweeter not working on 15" EON G2
I have the same problem and the same conditions.
The tweeter is good, 3.8 ohms.
Some points of solding (donuts), have bad aspect.
I resolder the power transistors to the PCB and I solve the problem.
Jun 05, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Tweeter "drive" out on wharfedale svp - 15
Hi bertsteenrt
Can you check the resistance of the HF driver(tweeter). If it is open it will need a new diaphragm. Most of these speakers use a lamp to act as protection for the HF driver. Sometimes these lamps fail. You will need to pull the horn out of the cabinet to check, and the rear connection panel off to get access to the crossover where the lamp is located. Get back to me here and I can talk you through fault finding the speaker.
regards
Graeme
Mar 21, 2008 | Audio Players & Recorders
B&W DM603 S2 Speaker Logo
46 people viewed this question
Top B&W Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Are you a B&W Audio Player and Recorder Expert? Answer questions, earn points and help others
