Question about Yaesu NABC NABC LMR NICD BATTERY FNB-V47 EQUIV. (NANBV47) 2-Way Radio
Yaesu ft 50r
I enter the VFO duplex modes on the proper frequencies in my area. I push the PTT and the unit keys quickly, beeps and ends the PTT by itself resulting in no transmission.
The unit eats batteries like candy so I have it plugged into the wall adapter because it wont stay powered up if I disconnect it. The battery installed is nickle hydride battery MH-FNB-41 battery pack DC 9.6V 1050mAh. Any solutions fellas?
  • 3,289 Answers
The FT-50R is an extended receive, but dual band (UHF & VHF) amateur transceiver. It is capable of transmitting between approximately 144Mhz - 148Mhz VHF and 430Mhz - 450Mhz UHF.
Typically, the radio will provide an audible warning whenever attempting to operate outside of its intended range(s). The manual has a section on maximizing battery life, and can be downloaded below:
http://www.radioamateur.eu/schemi/FT50_user.pdf
Posted on Sep 21, 2009
Menu mode 075 will not change the power settings
What freq and mode are you in? Did you lock out the vfo knob? Are you on a band that you can transmit on? More info please
Mar 17, 2016 | Yaesu FT-857D transceiver
Ft 2900r when I push then talk button on mic it shows error on all channels even with second mic
Sounds like a programming error. Does it work properly in VFO mode? Did you try a reset?
Jan 10, 2015 | Yaesu Ft 2900r Vhf Mobile 75 W Two Way...
On a baofeng uv-5ra. how do i change freqs. on channell mode? frequency mode works fine but it won't let me change the freqs. in channell mode. thanks.
You have to be in "VFO" mode. Your best bet on that extremely difficult to use radio, is to get "chirp" and the proper cable and program it via a computer. If you search on-line for "baofeng programming" you may find an alternate set of instructions. Your absolute best bet: throw that PoS away and get a Yaesu FT-60.
Dec 14, 2014 | Baofeng UV-5RA Dual Band Transceiver
Eeprom error ? B0003 on display
if a reset has failed, these means either the eprom or the cpu is damaged.
Feb 11, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu ft-50r HT getting very hot and not charging battery
From the description your battery has one or more shorted cells. Replace the battery.
Mar 15, 2010 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
FT-920: When the TUNER switch is pressed, the
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Jun 25, 2009 | Yaesu Radio Communications
I need a memory battery for a ft 50r both sides are sorderd the main board
I just had my FT-50R repaired due to a overheat issue with a reverse polarity diode. When I asked Yaesu to alao check my Yaesu for the memory battery I was told by their top technican that the radio does not have a memory battery in it. I hope this helps.
Apr 02, 2009 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Yaesu Ft-50 hard to turn on
The rubber power button is impregnated with carbon and when pressed, it makes contact with two points on the printed circuit board, turning on the radio. This button eventually wears out and needs to be replaced, which is a rather easy process.
I've performed the operation four times - takes about 15 minutes. The button is available from Yaesu.
I also tried "repair kits" for these buttons which are supposed to replace the conductive surface. Both times, they failed again within a couple of weeks.
The upside is the new button is not as quite as tall as the original and requires depressing it below the surface of the case to switch, which prevents accidently turning off the radio.
Good luck, and 73
DE NøAWN
Mar 17, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
Radio Communications Logo
837 people viewed this question
Top Yaesu Radio Communications Experts
Steve
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
