Question about Sharp AL-1655CS Copier
What happen if a developer is weak. the copier is
What happen if a developer is weak. the copier is not printing as it used to, copies is no longer sharp.
    Sniper:
  • 66 Answers
If your developer is weak it will do exactly what you are referring your copier as doing. The job of developer is to carry the toner via magnetism and put it on the drum, as it gets older it starts to weaken and wont carry as much toner. I would recommend you replace the developer and hopefully it gets your copier back up to the quality that it used to be at.
Posted on Sep 29, 2010
Bizhub 350 printing blank copy
Does you machine say replace PC drum on the control panel if so need to have the drum developer replaced at the same time. The code is dealing with the image unit the drum is one part the developer section is the bottom part or the sensor at the bottom of the image unit is bad. If developer was replaced did that person use a vacuum clean if so then the static electricity from the vacuum clean destroyed the sensor. NEVER USE A VACUUM to remove old toner. Worse case the main board that the sensor feeds is bad. Also when (if the drum and developer where replace did that person clear the counter for developer and drum. Machine works on info from counters to set certain voltages on certain assy. If the counters are not cleared then the copier thinks there is old developer and old drum in the machine and sets voltages for those units when in reality there are new drum and developer . Also after the developer was replaced was the required F8 run. And no prints/fax or copies where made before the f8 was run. When replacing the developer and drum the fax line and the Ethernet cable need to be removed first even used F8 and counters are done in service mode.
Mar 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Ricoh mp5500 printing light copie
Hello!
Is it only in copies? If so you need to clean the all scanner (glasses ans mirrors)
If that happens also when you print it could be one of this problems;
-The laser (durt)
-The Magnetic Roller (in the development unit)
-Or the Developer.
The question is: When was the last time that you did a service maintenence??? Maybe you need to do that.
See you!
Aug 15, 2011 | Ricoh Office Equipment & Supplies
Canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
Jul 02, 2010 | Canon Office Equipment & Supplies
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Photocopier not copying
MAY BE TONER IS NOT FEEDING OR CHANGE ITS DEVELOPER IT IS WEAK.MIAN AKHLAQ
Sep 30, 2008 | Office Equipment & Supplies
Longer warm up time accompanied by a loud grinding noise
There are few gears inside the copier that probably need to be replaced causing the grind and the copy quality to happen. It wasn't looked at by the engineer at the time because it happened after they left. They should come back in to fix it.
Aug 30, 2008 | Sharp AR-5316 Advanced Digital Imager...
Dc1q2
What is sounds like to me, it you need to replace the developer.
Once it is in the machine for an extended period of time, the ink no longer transfers onto the drum properly and your copies become washed out.
It is rather amazing the differenece a fresh shot of developer will make.
Mar 26, 2008 | Xerox DocuColor 12 Color Copier
Cyan Toner always prints faded.
It is the developer. All colours should be changed at the same time. This can be accessed via the right hand side of the machine, when you remove the cover. (where the output tray is)
Feb 06, 2008 | Xerox DocuColor 12 Color Copier
Light Copies Canon imageCLASS D320
hi im jules_09,check the developer,if its past over 60,000 copies if its over 60,000 copies you need to change the developer along with the opc drum and cleaning blade or roller,all copiers need to be replaced with new developer,opc drum and cleanign blade or roller when it reach its copy life,that may be the cause of light copy of print
Nov 21, 2007 | Canon imageCLASS D320 Digital Copier
Sharp AL-1655CS Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
