Question about Remington Titanium SmartSystem R-9500 Electric Shaver
I am having problem taking the back off my R-9500 Electric Shaver, I removed 2 screws, one at the bottom & other near button for trimmer. I have pushed the the trimmer button up to open the trimmer, but can not find the 3rd screw, the shaver halves are apart but the top half near the trimmer is still attached, so please can you help me. Thanks Rob
  • Anonymous Mar 23, 2014
    see above
  • Remington Master
  • 1,602 Answers
The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body.
Posted on Sep 29, 2010
HELLO: I HAVE A REMINGTON R-9500 IT WONT TURN ON SO I OPENED AND NOTICE THAT ONE CIRCUIT AND THE BATTERIES ARE CORROTED ALSO SOME TIMES THE SHAVER BECOMES EXTREMELY HOT PLEASE HELP ME IS A BRAND NEW
Model R-9500 has been discontinued for several years. It is very possible that the batteries are dead because they are so old. You may need to replace them. You will find the correct battery type at shaveroutlet.com. See link below. You will need 2
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To change batteries, remove three screws on back. The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body. Remove back cover. Inside, remove the metal clip that covers the batteries near the bottom of the shaver. Unsolder the batteries from the wires. Solder in the new batteries.
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Jul 14, 2011 | Remington Titanium SmartSystem R-9500...
Tip
How to to replace batteries in Remington MS-5200 Electric Shaver
<span>Hi, to change the batteries you will need to remove the back cover. There are 3 screws. 2 can be easily seen. The third is under the trimmer wher it hinges to the shaver. You will need to carefully pry out the trimmer to get to it. Once screws are removed, you can take off the back. Inside, remove the metal clip to access the batteries better. Then, unsolder the wires from the battery tabs. Install new batteries by soldering to wires. Reassemble in reverse order...</span>
on Dec 14, 2010 | Health & Beauty
What is the replacement battery for R9100 razor and how is it fitted
Jan 16, 2011 | Remington MicroFlex R856 Electric Shaver
I have a brand new remington r 9500 r rotary shaver which does not get charged when its adaptor is plugged into an wall power outlet. Please advise me to make this shaver do its job. Returning the item may...
Dec 30, 2010 | Remington Titanium SmartSystem R-9500...
I have a braun 5564 electric shaver i think the battery is dead can i get a new one and how do i replace it
You will need to replace the battery pack. Depending on when your shaver was made, it may have one of two different battery types. You will ned to look inside to see which you need before ordering.
To open, remove the two round screw covers on the bottom of the shaver. Remove screws to remove bottom of shaver. The outer case will then slide off the bottom. Push the trimmer up to be abl to take the circuit board out. BE CAREFUL not to detach trimmer oryou will not likely get it back on yourself.
Your battery(s) will be one of the two types below found at shaveroutlet.com
http://shaveroutlet.com/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Be sure to read the Note on the second link concerning instalation
If you are unable to do this yourself, shaveroutlet.com can do the repair for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Oct 28, 2010 | Braun Flex XP 5614 Electric Shaver
How many torx head screws to remove cover of 6863xl. Will trimmer need to be removed? Is so how?
On model 6863XL, there are just two screws near the bottom on the back. Remove the screws to remove the back cover. Trimmer will come off with the back cover
If you require parts, you will find them at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=6863xl
Sep 23, 2010 | Norelco ReflexPlus 6863 XL Electric Shaver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
What is the procedure for replacing the batteries in the Remington Titanium R 9500?
There are three screws on the back of the shaver to be removed. One is easy to see. The second is visable when you extend the trimmer. The third is hard to get to and the trimmer must be disjointed at the top to get to it. Once all three screws are removed, you can remove the back cover. There are two batteries. To remove them you will need to unsnap and remove the long metal clip and then unsolder the wires connected to the batteries. There may also be a gummy substance holding a wire to the side of one of the batteries. You will need to use a razor blade to seperate it off along the side of the battery. Once the old batteries are removed, you can solder in new batteries and ten reassemble the shaver.
You will find batteries at shaveroutlet.com. See link below. You will need to order two.
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
If you are unable to do this repair yourself, shaveroutlet.com can do it for you. See link below.
Mar 15, 2010 | Remington Titanium SmartSystem R-9500...
My shaver will not hold a charge. What could be the problem
Remington model R-9500
Your shaver will not hold a charge because the shavers internal batteries need replacing. If you know how to solder, you can do it yourself or you can have it professionally done. You can purchase batteries or professional repair service from shaveroutlet.com. See links below.
If you feel this is something you want to try yourself, you will need to remove the back cover of the shaver. You will easily notice two screws on the back. There is a third screw that is near the very top on the back and it is underneath the trimmer where the trimmer connects to the shaver. Remove these 3 screws to take off the back cover.
Inside you will see the batteries. You will need to remove the metal clip that helps secure them into place. You will then need to use a soldering iron to remove the wires from the ends of the old batteries. Solder the new batteries to the wires and put everything back together in reverse order
Once the job has been completed, charge the new batteries for 24 hours.
Jan 24, 2010 | Remington Titanium SmartSystem R-9500...
How do I open the Remington 9190 Electric Shaver to replace the battery?
Remove the Two ( 2 ) Phillips Head screws on the Back side of the
R 9190 shaver near the Electrical Plug .
Pry off the Gray Rubber cover that those two ( 2 ) now removed screws went thru.
Now remove the Two ( 2 ) exposed screws up near the " Trimmer Switch "
Note: If you Popped off the " Trimmer Switch " during your efforts - DON'T WORRY . It will simply pop back in place when you are finished with your repairs.
Jun 21, 2009 | Remington R-9190 Electric Shaver
Remington Titanium SmartSystem R-9500 Electric Shaver Logo
77 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
