Question about Texas Instruments TI-84 Plus Calculator
It cannot be turned on even though the batteries are new.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Posted on Sep 29, 2010
NS Pajero struggles to turn over even though it has a new battery
starter motor
starter relay
ignition key or unit fault
Apr 08, 2016 | 2009 Mitsubishi Pajero 3.2
G.P.S. will not turn on after replacing new battery
Even though the battery is new, it may need to charge fully before it will operate your unit. If the battery has been on the shelf for a while it may not have enough charge to work properly.
Sep 20, 2014 | Garmin nuvi GPS
My Samsung WB100 turns off after switch on. Got new batteries and same problem plus 'old' batteries are still good even though camera said they needed replacing after a few days minimal use.
Make sure you are using name brand high quality batteries and not some generic from China. Camera require a great deal of power to boot up.
Jan 25, 2013 | Samsung Wb1000 Digital Camera
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
My Dynex Wireless Optical Mouse just stopped working
If the mouse light is not turning ON even though you have new batteries and the mouse is turned on, then you need to contact the manufacturer for RMA.
Thank you!
Dec 22, 2009 | Dynex Wireless Optical Mouse
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Won't turn on
Your battery is dead. get a new battery
Aug 19, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Texas Instruments TI-84 Plus Calculator Logo
16 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
