Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
My garage door wont open more than 6 inches with the door attached to the belt, but when I releasae the door load the belt works just fine. It worked fine for 6 months but now i have this problem....
  • 504 Answers
YOU MAY HAVE A BROKEN SPRING
CHECK TO SEE HOW THE DOOR WORKS MANUALLY - DISCONNECTED FROM THE OPENER. IF YOU CAN'T LIFT IT EASILY THE SPRING MAY NEED TO BE ADJUSTED OR REPLACED.
IF IT LIFTS EASILY BY HAND THEN LUBE (WHITE LITHIUM OR WD-40) THE SPRINGS, HINGES AND OPENER RAIL - TRY IT AGAIN, IF IT STILL REVERSES ADJUST THE OPEN SENSITIVITY 1/8 TURN AT A TIME IF IT TAKES MORE THAN 3/4 OF THE ADJUSTMENT RANGE OR STILL DOESN'T WORK I WOULD HAVE IT LOOKED AT BY A PRO. SOME THINGS YOU CAN LOOK RIGHT AT AND NOT SEE.
HOPE THIS IS HELPFUL
Posted on Oct 05, 2010
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Genie Powermax 1200 installed but only move approx 6 inches at a time.
You need to program the unit for up and down stops you can download the instructions from the link below
http://www.geniecompany.com/data/products/genie_programming-excerpt_eng.pdf
Jan 02, 2013 | Home Security
Press the button for the garage door to go down and it will only travel a couple of inches and shakes. Unlatch the door and press the button and the door will catch the latch on the way down and close. ...
Most likely cause is the load limiters. Firstly, the door needs to work perfectly, when worked manually. No stops or restrictions through entire movement. Then reset the load limiters to spec and test again. Up limit is not extremely critical, but the close load limit can save lives and prevent vehicle damage.
Jul 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
The belt on my Chamberlain Whisper Drive dipping
Where the belt attaches to the trolley carriage which attaches to the door there is a black adjustment nut with a spring on it. Tighten it up more by turning it clockwise until the belt tightens up. The belt will droop a little when the door is all the way shut normally but should not during operation. If you tighten it up too much the belt will slap on the rail during operation. Make sure the spring is set on the adjustment screw too. This holds the belt tight over time. Thanks BB
May 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Nov 07, 2009 | Chamberlain 1/2-HP Whisper Drive Belt...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster Remote garage door openers work intermittently.
check to see if your ant. is up inside of the cover it's a little black wire that hangs outside of the operator shiould be about 6 inch.
Jun 02, 2009 | liftmaster Chamberlain Garage Door Opener...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
435 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
