Question about Kenmore Elite 45986 Front Load Washer
I am getting an F06 error regularly when trying to wash. What does that error mean?
    Genius:
  • 1,416 Answers
what this code indicate on the screen is that there has been an over floe of water on the panel of the washer i.e the the power distributor to different unit of the washer.
thanks
Posted on Sep 29, 2010
What is error code F06
The "F06" fault code indicates a drive motor error. This means the control is unable to properly detect motor speed and the machine will shut down.
Mar 17, 2016 | Whirlpool Duet GHW9150P Front Load Washer
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
My washing machine is giving me an error message F06, what does that mean?
F06 is Drive Motor Tachometer Error.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) .
• Check the Drive Motor .
• Check the MCU .
• Check the Wire Harness .
Please read the below link it is an article about this error from one of the senior and best expert here
http://www.fixya.com/support/t2946429-kenmore_elite_he3t_giving_code_f_06
COURTESY:JSROCK
Mar 21, 2010 | Whirlpool Washing Machines
Often fails to execute spin cycle with error F06
THE F6 MEANS THE CONTROL IS NOT GETTING A READING FROM THE TACHOMETER ON THE MOTOR. CHECK THE CONNECTIONS FROM THE MOTOR TO THE MOTOR CONTROLLER,(THE CONTROL BOARD MOUNTED TO THE BASE).
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing code F06, currently will not do anything
The F06 error is a drive motor tachometer error. This means the motor is not running or if it is then the tachometer circuit in the motor has failed. This error will be a failure of the motor or the motor control. both expensive and the motor being being the more difficult one try unplugging if for no less than 5 minutes to flush all codes... to see if it wasnt an intermitent problem. hope this helps......
Oct 24, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
135 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
